70chevy c20
I'm looking to replace the drivetrain on my 3/4 ton 4x4 chevy. The 8 lug rear end burned up so I would like to replace with with higher gears.Also replace the front w/disc brakes 6 lug. Found a 72 K10 blazer parts truck with good drivetrain with 3:73 gearing,possi. Will this fit without changing or relocating the spring berches on the axle ? Would appreciate any information.
thanks, Charlie |
![]() Join Date: Feb 2000
Yes, spring perches will be in the correct location.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
70 c20 4x4
I read somewhere that there was some difference between c30 c20 and c10 4x4 spring perch width on model changes 67-70 to 71-72 ? Do you know of that difference.
I'm just looking for an easy swap and if the 72 K10 4x4 blazer drive line would replace my my c-20 4x4, I'm good to go. So you know for sure that the width is the same? Appreciate any help. Thanks ,Charlie Last edited by schu; 06-10-2004 at 11:55 PM. Reason: to clarify |
#4 | |
All my trucks are gone now. ![]() ![]() |
some c20's had leaf springs while most had coil. If yours has coils then, the rear from the k5 bazer will need the pads & trailing arm mounts added.
I'm reffering to 4x4 drivetrains.
huh ???
All the 4x4's are leaf springs...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
