Old 09-02-2004, 07:43 PM   #1
skokie
skokie's Avatar
Changing Driven Gear
How do you change out a driven gear for a 400 turbo?
skokie is offline   Reply With Quote
Old 09-02-2004, 08:05 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Unscrew the speedo cable off the trans. Next, you remove the one bolt that holds the gear housing in and pull the housing. The driven gear just slides into the housing after you revove it.
I attached a picture of my turbo 400 so you can see the housing and bolt that holds it in.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-02-2004, 08:06 PM   #3
Tx Firefighter
PS Brad, you have UPS package on the way.
Old 09-02-2004, 08:20 PM   #4
skokie
skokie's Avatar
Thanks Tx Firefighter. Isnt there another gear in there as well that may need to be swapped out?
