Anybody have a BB in a 60-66? I would like to see how yours fit
LIke the title says, how does your big block fit in your 60-66?
Youth soon passes away, but immaturity can last a life time. |
yes,but not chevy.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
lets see it anyway
I have a 454 BB, do you still want pics?
BBC in a Chevy
Hi put a 2-454 BB into 1966 Chev Suburban's. The first one I had to massage the drivers side firewall (which I did not like to do). The second one I moved the entire drivetrain up 2.25", so my firewall looks perfect. The body is at a shop getting redone, so at the moment All I have is a frame with the running gear. Not much to look at for pictures.
Here is a 348 w-block that I have in mine. Its almost the size of a 454. I had to do the same thing to the drivers side firewall and shave a little (needed to be 1/2" wider) off the passenger frame rail for the exhaust manifold to get her in. This was using the factory tranny mount.
I got a 454 in my '60 GMC Sub 4x4....the passenger side frame rail had to be clearanced slightly for the exhaust manifold, and on the driver's side valve cover, I used a Corvette BB valve cover to allow fitment without cutting the firewall. The Vette valve cover has a large angle in it at the back end to allow for clearance in a Vette.
![]() Join Date: Apr 2001
how do you like that 348 in there... ive toyed with that idea for my 63, wanted to try a 348/4sp combo.... any opinions???
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
#9 | |
If you can find one cheep then great... But they are alot more spendy then a 350. I lucked out and got this one for a case of beer. I have 160$ into the whole truck and am using it as a DD right now ![]() |
454 club
I am going to be putting a 454 in my 65 in a couple of weeks.
David 1965 Chevrolet c-10 454 automatic Custom bbw swb. 1965 Chevrolet C-10 swb (Sold) 1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's. R.I.P "I will miss you. 1967 Chevrolet C-10 6 Cyl Custom lwb 1939 Chevrolet Coupe, 350 v8 automatic. 1935 Chevrolet 2 Dr Standard in the works. 2015 Harley Davidson Street Glide. 2023 Chevrolet Stingray Z51 Convertible. I never want to grow up. |
I had the same problems as you guys did. I had to move the enginve forward about 2.5 inches and take the spacer that was between the radiator and core support out so my fan would clear the radiator.
