HEI Timing
For you folks with a hei on your smallblocks. What do you have you idle timing set to?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
#2 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
![]() Join Date: Mar 2003
I've got mine set at 6, 400 small block, 5.7 rods, crane 268 cam
#4 | |
Settings would be the same for points distributors or HEI distributors for initial timing. We set our small blocks at 10-12 degrees BTDC with the engine idling and the vacuum advance disconnected.
Jim |
![]() Join Date: Apr 2004
8 degrees BTDC is a good starting point. From there you can bump it up as long as there is no spark knocking and it does not hold back on the starter when trying to start.
1968 Chevy 4x4 307 4 speed |
