Steering Colum
When I put in my floor shifter what can I do about the colum were the old shifter was. Can I just get that cover off a truck with a manual and swap them right over?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
Re: Steering Colum
Changing out the column collar can be a big pain, best to get a Manual column and do a straight swap. Auto columns are selling good on fleabay if they are in nice shape, or maybe you can find a member to swap you straight accross.
![]() ![]() Join Date: Feb 2004
Re: Steering Colum
You can do body work on the manual collar as I did and you cannot tell the difference. Will send you a pic if needed. Of course if you have a floor shift collar--- a lot easier.
![]() Join Date: Sep 2005
Re: Steering Colum
mine was converted over to the floor and i'd like to get ird of the ungly collar on my cloumn lol
Re: Steering Column
pic of a converted 3 on tree. Remove, cut or gring pot metal shifter protrusion. Clean, Use a lab metal or hardner to fill nost of the hole, finish off with good old bondo.
its all about the +6 inches
Re: Steering Colum
Removing the colar off a 4 speed truck is simple, as is installing it onto your column.
