Old 10-30-2005, 11:43 AM   #1
72longbed
72longbed's Avatar
Exclamation WTB Front 4x4 Driveshaft
Looking to buy a new front driveshaft for my 71/72 K20. Need one that the slipjoint is working properly and is not bent. Having good U-joints would be good too.
BTW, does anybody know if a 'stock' front driveshaft will allow for a 4" lift??
Thanks,
72longbed
72longbed is offline   Reply With Quote
Old 10-30-2005, 04:34 PM   #2
GM72K10
Next!
GM72K10's Avatar
Re: WTB Front 4x4 Driveshaft
Hey 72 Longbed
If you can use a "used" front driveshaft, I have a few laying around. Takes time to do these things doesn't it.
GM72K10
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 10-30-2005, 05:00 PM   #3
bisquik65
bisquik65's Avatar
Thanks,
72longbed
I have a front shaft from a 72 blazer that had a 3 speed trans...It may be longer than the pickup one...If you could get me a measurement close,I will check mine...If it will work...$60 shipping included...Thanks,Erick
And my 69 K/20 had a 6 inch lift with stock shaft...worked fine...
bisquik65 is offline   Reply With Quote
Old 10-30-2005, 07:54 PM   #4
72longbed
72longbed's Avatar
Thumbs up Re: WTB Front 4x4 Driveshaft
GM72K10,
Hey Gerry, how ya' been? It's good to hear from you again. A used shaft is OK as long as the slipjoint is not siezed up and works in and out freely and the tube is straight. Send me a PM with your phone number and I'll call to set up a time to stop over.
BTW, do you have any of those transfer case boot rings that hold the rubber boot to the floor?
Thanks,
72longbed
Old 10-30-2005, 07:57 PM   #5
72longbed
72longbed's Avatar
bisquik65,
thanks for the info on the shaft. If I can't find one local, I'll be back to you on that measurement.
Thanks,
72longbed
Old 10-31-2005, 01:45 AM   #6
69TowRig
From what I remember when I got mine all the front shafts were the same length between blazers and pickups (I have a 3-spd blazer). Of course the used one I bought is still in the box because I have not made it that far along in my Blazer's resurrection. I will see if I can't confirm it for you tomorrow.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 10-31-2005, 06:57 AM   #7
GM72K10
Next!
GM72K10's Avatar
pm sent
86 K30 CUCV M1028A1
Old 10-31-2005, 09:58 AM   #8
72longbed
72longbed's Avatar
Question Re: WTB Front 4x4 Driveshaft
I took a measurement yesterday of the front drive shaft distance and it is approxiametly 30.25" from back of U-joint cup at the transfer case to back of opposite U-joint cup at the Dana 44 (deepest length). Now here's the thing though ; the cab, front clip, and transmission are not in the frame right now so I don't know how much more the frame will settle down and if that will change the length dramatically. The frame has a new 4" Tough Country spring lift on it so the springs are pretty stiff right now. From what I have read on this Board, the 'slipjoint' should allow for some variation in ride height?? Yes or No??
Thanks,
72longbed
Old 10-31-2005, 04:17 PM   #9
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I use a SJ 4'' lift on my 72 4x4, no problems with the front drive shaft. I don't recommend extreme four wheeling.
D.PASSMORE is offline   Reply With Quote
Old 10-31-2005, 06:43 PM   #10
GMC AMI
GMC AMI's Avatar
You have to worry more about the rear shaft, front one is cool! I have a bigger lifted 68, about 9" total, and the rear shaft looks to be a little short and not the front. 9 inches taller than my stock 68 4x4. The only bearing hard to swap is the little one in the center of the double joint. I just rebuilt my front shaft.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
