Old 02-27-2006, 06:54 PM   #1
harlyworkr
harlyworkr's Avatar
Help!! Difference in 4 speed Bells
Is there a difference in a 292 6cyl 4 speed bell and a 350 V8 4 speed bell for a 2wd truck? I have the flywheel hitting the bell when I converted to a 91 LT1 350 crate motor for my 69 C10. Any help will be appreciated.
harlyworkr is offline   Reply With Quote
Old 02-27-2006, 09:22 PM   #2
JAKES 68GMC
Aluminum slot wheels rule...
Re: Help!! Difference in 4 speed Bells
Doesn't seem like there would be, but I'm no expert on this truck stuff.
JAKES 68GMC is offline   Reply With Quote
Old 02-27-2006, 10:26 PM   #3
NitroMike
Active Member
NitroMike's Avatar
Not sure. You probably had a 168 tooth flywheel on your 292, but the later set-up used a 153 tooth (smaller diameter) flywheel. Try to use the flywheel that would have come with the later motor and trans.
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 02-27-2006, 11:04 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You need to assure that the tooth count of the 292 flywheel was the same as your new 350 flywheel is, either 153 or 168.
Coincidentally, I just swapped this same swap, twice, in the last two weeks in my own truck, 292 to 350, then back to 292. Same bellhousing for all of them.
I then took the 4 speed out and went automatic trans. It was a busy week.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-28-2006, 04:50 AM   #5
rwgregory
Tx Firefighter, just out of curiosity do you use standard nuts and bolts or just
hold everything together with wingnuts seeing as how it only has to hold for a
day or two.....
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
