Old 07-12-2006, 12:50 PM   #1
swb85
On a budget like Fred Sanford
swb85's Avatar
might be doing cam swap, help decide.....
Pretty sure I have a collapsed lifter, haven't torn it down to verify yet. If it is, I'll probably go ahead and do a cam/lifter swap since I don't know any of the current cam's specs (PO installed it). Thinking about these cams:
Comp 268H: 218/218 .454/.454 110lsa (1500-5500 rpm)
Comp 265DEH: 211/221 .42/.465 110lsa (1500-5750 rpm)
Comp 275DEH: 219/229 .452/.482 110lsa (2000-6000rpm)
Comp XE268H: 224/230 .477/.480 110lsa (1800-5800 rpm)
Motor is a 355 with stock iron heads (mildly ported according to PO), I assume 76cc chambers?(no clue here), performer rpm intake, edel 1405 carb, longtubes/2.5" duals, muncie 4 speed, 3.42 rear gears. No idea on bottom end or pistons. The current cam is aftermarket, has a tiny chop to it at idle, so I think my current valve springs are probably ok (only 12k miles).....would like replacement cam to have close to same overlap, maybe a hair more. Not gonna say no to a bumpin' idle. Anybody have any input? Other recommendations? The 224/230 is probably as big as I'd go.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 07-12-2006, 01:27 PM   #2
SSC's76
No No
SSC's76's Avatar
Re: might be doing cam swap, help decide.....
Alll of the above cams really require screw in studs and beafy springs.1, 2 and 3 would suit your needs. 2 Would be the best choice IMO.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 07-12-2006, 02:12 PM   #3
swb85
swb85's Avatar
I pulled the valve cover over lunch but didn't get any further......it looks like there's already aftermarket valve springs and studs in there. I was actually leaning towards the 265DEH......glad you agree.
Old 07-12-2006, 07:02 PM   #4
SSC's76
No No
SSC's76's Avatar
You might also consider a crane E seiers 266. It's close to the comp 265 but has slightly more truck friendly atributes. It also idles like a dream. I have one in my 383 and if you do any highway drving the fuel economy is amazing @2600 I get close to 22MPG.
Old 07-15-2006, 02:16 PM   #5
Tom
driving is in my blood
Tom's Avatar
Those cams don't need screw in studs IMO, but I would go with a XE262 or even better a lunati voodoo equal.
Old 07-15-2006, 09:16 PM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
The Comp Cams company profiles their cams with a sharper drop off of the top of the cam lobe. This is where the slightly choppy idle originates. The Crane Cams and Lunati have a slightly different slope and it provides for a longer ramp down off of the tip. This type of cam IS more friendly and will have a longer life over the Comp Cams. Don't get me wrong, I love the work Comp does and I am even running a roller comp cam in my 383 stroker on my 84 GMC, but I have had experience with the others and their profile is a good thing to look for.
Old 07-16-2006, 01:41 PM   #7
SSC's76
No No
SSC's76's Avatar
Yep, thats also the reason if there is a casting material problem with a comp cam it will likely go flat where as the others are not as likely to go flat or as quickly.
Old 07-16-2006, 02:03 AM   #8
89 crew
Back in the 60's there was a cam for the vet 327 that put out 375 hp. It came factory with solid lifters. I don't know how it would work for you, but I had a lot of fun with it in a 400 with hydraulic lifters and a high vol oil pump. A 1 ton van with 4.11's that can turn 6000 rpm made it quite the insulter.
89 crew is offline   Reply With Quote
