Old 08-29-2006, 10:44 PM   #1
Dadsredwagon
Dadsredwagon's Avatar
new here a fews q's
Live in Houston , tx Just bought a 65 fleet side swb straight six
ok some rust in the cab near the lower vents , is this a common problem for these trucks I did some research and found some companies that offer floor pans (Agood deal) , but I need to stop water coming in, any ideas where to start?
Thx,
Todd
Dadsredwagon is offline   Reply With Quote
Old 08-30-2006, 02:54 PM   #2
bpmcgee
bpmcgee's Avatar
Re: new here a fews q's
The vents get their air from the cowl grill. It's perfectly possible for water to run down from the grill and into the vents.
If the water is getting inside, it probably means that the vent seals are old and not working correctly. Imagine that, in a 41 year old truck!
Brian
bpmcgee is offline   Reply With Quote
Old 08-31-2006, 05:26 AM   #3
mbgmike
Plus all the trash that can build up inside(like leafs and old wasp nests)
mbgmike is offline   Reply With Quote
Old 09-01-2006, 02:20 AM   #4
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Check the rubber silicone in the drip rail, if it is all cracked up or is gone, water will leak in here, and run down the A & B pillars. Next time water starts leaking under the dash, use a flashlight, and shine up the bottom of the A pillar.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 09-05-2006, 09:19 PM   #5
65Gregg
65Gregg's Avatar
Unhappy Re: new here a fews q's
Also check your window felts, if they are bad this allows water (rain) to run down inside the doors which then drains out from the drains in the doors and can then collect near the vents and also can get to your rocker panels depending on the angle the truck sits. experience taught me this lesson....
65Gregg is offline   Reply With Quote
