Old 09-03-2006, 06:25 PM   #1
CochinoFilipino
CochinoFilipino's Avatar
How low is too Low?
My truck is lowered to the point where the outside of the lower control arms sits higher than the inside. Would this put any abnormal stress on the suspension? The rear cross shaft U-bolt busted off my right lower control. I was wondering if bad suspension geometry may have caused the bolt to break.
Thanks,
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
Old 09-03-2006, 07:44 PM   #2
7deuce
Sold! 2 days after finished
7deuce's Avatar
Re: How low is too Low?
What bolt?
7deuce is offline   Reply With Quote
Old 09-03-2006, 07:46 PM   #3
7deuce
7deuce's Avatar
My fault didnt read very well. Did you do this while driving ex. smash in to a man hole cover or dragging?
Old 09-03-2006, 09:23 PM   #4
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
the balljoints most likely hate life....
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 09-03-2006, 10:33 PM   #5
CochinoFilipino
I was just re positioning in my driveway after installing a bench seat. I had to disconnect the shifter to do this. And put it in Drive by just pulling cable. I thought the BanG! CluNk! noises had to do the shifter not being adjusted. Nope. It's strange how often something completely unrelated breaks when some work is done.
I did have it up on ramps to get a look at the underside of the trans tunnel. But that shouldn't have been a problem if everything was right.
Fortunately this happened at slow speed and right in front of my house.
Old 09-03-2006, 10:38 PM   #6
CochinoFilipino
So it's not good? I may raise it up with some coil spacers if it's causing problems.
I did seem that the outside tire (right) may scrubbing excessively on tight left turns. Like it's not turning in enough. And I have a very wide turning radius.
Good thing I didn't sell my Jeep yet. I was going to put her up for sale this weekend.
Old 09-03-2006, 10:55 PM   #7
7deuce
7deuce's Avatar
was the cross shaft seated in the hole drilled out for the pin in the shaft?
Old 09-03-2006, 11:35 PM   #8
CochinoFilipino
I didn't notice. I'll take closer look at it in the AM.
I didn't lower it myself. It was already done when I bought it.
Old 09-04-2006, 03:59 AM   #9
blt2rail
land of the free ya right
blt2rail's Avatar
to answer your question you can never be to low
73 c10 body droped bagged zed frame 20s 2link 350,350
03 dodge crew cab 4x4 cummins banks 6 gun 4 in exhaust 4in lift 35s 16.5 5th wheel hitch xm linex
33 foot weekend warrior
06 chrysler pacifica (wifes)on 19s
00 xr 650 supermotard for sale$$$$
98 honda accord (commuter)
blt2rail is offline   Reply With Quote
Old 09-04-2006, 11:57 AM   #10
camaro__thunder
You can be too low to be functional.
Check the angle on the Lower balljoints.
My Project 69 SWB
Old 09-04-2006, 12:40 PM   #11
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
If your window will not roll down all the way because you drug through your door and your window now hits the ground, you might be too low.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 09-04-2006, 01:00 PM   #12
7deuce
7deuce's Avatar
All I know is I STILL cant get my FU@KIN Hood to work cus the tires are blastin throught the fenders. I feel like I should be on a JEGS cover with no hood. Maybee Ill use hood pins on all 4 corners Hmmmmmmmmmm.
Old 09-04-2006, 02:03 PM   #13
BigMike
BigMike's Avatar
Mike
BigMike is offline   Reply With Quote
Old 09-04-2006, 04:12 PM   #14
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
You mean you're LCA's at the spindle are higher than at the crossmember and you're static???? Holy crap that can't be good.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 09-04-2006, 10:59 PM   #15
CochinoFilipino
That's exactly what I mean. I either need coil spacers or new springs to bring it up.
I'm thinking of getting the 2/4 drop kit from Early Classic. What do you guys think of the KYB shocks in that kit?
Old 09-05-2006, 12:08 PM   #16
bodydropped
naw u know ur low when u can reach out ur window and can touch the ground with ur hand but ive seen guys with a 14inch b/d
bodydropped is offline   Reply With Quote
Old 09-05-2006, 02:30 PM   #17
67Fleet
67Fleet's Avatar
I'm not quite understanding how if it's that low that you're able to drive the truck. Isn't the crossmember basically on the ground at that low?
-Bret
Old 09-05-2006, 04:20 PM   #18
CochinoFilipino
It's not that low. It looks like the 3.5"/6" in the Early Classics catalog. But whoever lowered it did not use drop spindles. Once I get the new U-bolts in, I'll take some pics. I'm pretty sure I'll just put in some new 2" drop springs in the front and be good.
Old 09-07-2006, 04:39 PM   #19
el curioso
el curioso's Avatar
we need pics
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 09-08-2006, 12:23 PM   #20
leftcoast66
leftcoast66's Avatar
mine has always sat that way w/ airbags. Wen I drive it it's that way too and i haven't had any problems with tires or balljoints
leftcoast66 is offline   Reply With Quote
Old 09-08-2006, 01:06 PM   #21
CochinoFilipino
I don't think that was the problem. Here's a pic of the bolt that failed, next next to the replacement bolt. To think I have driven this down the freeway. All future hoopdies that I acquire will get a thurough inspection before I drive it. I hope that whoever put this on my truck has stopped playing mechanic.
Old 09-08-2006, 01:45 PM   #22
Alvin
Never Done?
Alvin's Avatar
The factory U-bolts are much smaller on the 67-72 trucks than on later trucks. When I replaced mine, the new bolts didn't even come close to fitting in the same holes. Had to drill 'em out to get the bolts to fit.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 09-08-2006, 05:05 PM   #23
CochinoFilipino
But not that small. The other three bolts on the truck are much closer in size to the new bolt. And thanks. I was having a problem getting the new bolt in. It's just slightly too wide. Now I know this is normal. I can't get my drill motor under there, figured I'd just lay there and file away.
Old 09-12-2006, 05:45 PM   #24
CochinoFilipino
Finally took pics. I replaced the one undersized bolt. If I can get acceptable camber, I'll leave it as is.
Old 09-12-2006, 07:07 PM   #25
roj2323
it looks like someone hacked the springs.
roj2323 is offline   Reply With Quote
