Old 11-11-2011, 12:31 AM   #1
RyanKohler84
RyanKohler84's Avatar
New to the site
Hello All,
I am new to the site and I have a 68 swb that i am starting to restore. I was wondering if anyone has attempted to lower their bench seat. I want to keep the original look but i want the seat to sit lower in the cab. Anyone have any ideas.
RyanKohler84 is offline   Reply With Quote
Old 11-11-2011, 03:37 AM   #2
dmack91
dmack91's Avatar
Re: New to the site
Probably have to section out the risers that the seat tracks sit on. I have seen it done on some trucks using different year seats and mounts. I would be careful if you are tall though. If you normally run the seat all the way back, as most do, and you move the seat down, the back of the seat would probably start to tip forward from hitting the back of the cab or tank.
BTW - welcome to the board. It is a great resource and the members are 10's!
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-11-2011, 08:27 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: New to the site
Some of the seats have shorter risers than others but for the life of me I can't remember what determines this, year or type of seat... I will see if I can remember to take some pictures of the difference in the morning.
Oh, and welcome to the board...
LockDoc
Leon
Old 11-12-2011, 11:43 AM   #4
LockDoc
LockDoc's Avatar
Re: New to the site
Ok, I went out and took a couple of pictures. The front on these seat risers/adjusters are the same height but the backs are different. If you swapped them out all it would do is lower the back of the seat. If you look at the labels on the pictures the metal panels on the back of the seat frame are different. I would guess that the seats are from different manufacturers but it may also be a year specific thing. It could also be the difference between the deluxe (full foam seat) and the standard seat. If anyone knows for sure post it up on here... I don't know for sure what years these seats/adjusters are out of. Anyway replacing the taller ones with the lower ones wouldn't really lower the seat.
LockDoc
Leon
Old 11-14-2011, 07:11 AM   #5
RyanKohler84
Re: New to the site
Thanks for the help. I may just put this plan on hold for a bit until i can find a way to do it correctly. I was hopping it was going to be as easy as just notching out the brackets and welding them back together. Thanks again for all the help.
Ryan
Old 11-14-2011, 08:08 AM   #6
hjewell2
hjewell2's Avatar
Re: New to the site
hjewell2 is offline   Reply With Quote
Old 11-14-2011, 01:33 PM   #7
slomotion
Old Duffer
slomotion's Avatar
Re: New to the site
Welcome to the board!
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 11-14-2011, 04:26 PM   #8
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: New to the site
Welcome aboard from Central Florida! This place is the best..hands down.
You can always fab up some fixed mounts..I did these out of C channel as a temp solution but I kinda like them this way.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 11-15-2011, 12:12 AM   #9
trkfrk
trkfrk's Avatar
Re: New to the site
Welcome aboard!
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 11-15-2011, 02:14 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: New to the site
Welcome!! From just a short hop down the road.I have later model seats in mine but it's all different than a pick up.I built the risers from Angle and square tube to fit "Mitsubishi"(I think) seats in mine.They were way too shor and needed the boost.
Keep your eye on the meets/regions forum for a gathering near you.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
