Old 08-25-2007, 05:55 PM   #1
jlaird
jlaird's Avatar
driveshaft loop crossmember
has anybody cut off and reinforce the bottom of this crossmember so it is level with the bottom of the frame? If so, pics and advice would be great.
josh
jlaird is offline   Reply With Quote
Old 08-25-2007, 07:31 PM   #2
fastom
That's right, it's Copper!!
fastom's Avatar
Re: driveshaft loop crossmember
I installed the one from Early Classic, very nice peice.
fastom is offline   Reply With Quote
Old 08-25-2007, 07:53 PM   #3
BigShoe24
True Addiction
BigShoe24's Avatar
Same here, EC, $199. Looks great, good function as well.
BigShoe24 is offline   Reply With Quote
Old 08-25-2007, 08:46 PM   #4
smbrouss70
smbrouss70's Avatar
Check out fletch4x4's thread - 4-link and a turtle... LINKY
I think he did a good job on his.
Here's a couple of pics.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 08-25-2007, 10:15 PM   #5
jlaird
jlaird's Avatar
that is exactly what i was looking for. he did a nice job on that. thx for the link.
Old 08-26-2007, 12:27 AM   #6
Frizzle Fry
Frizzle Fry's Avatar
That's on my to-do list too. Already moved the hoop up. Just need to flatten the bottom. Why not go with the ECE piece? Because I'm not doin a body-off... yet.
Frizzle Fry is offline   Reply With Quote
Old 08-26-2007, 08:54 AM   #7
jlaird
jlaird's Avatar
When I take this crossmember out to modify it, do you think I would need to brace the frame there at all if the truck is on jack stands with the cab off?
Old 08-26-2007, 10:56 AM   #8
smbrouss70
smbrouss70's Avatar
Couldn't hurt.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 08-26-2007, 05:22 PM   #9
action
Active Member
action's Avatar
How high can you raise the top of the loop before it would hit the cab floor? Mine will not be as low as some, so not worried about the bottom but want to run a 1 piece drive shaft so need the room on top. Don't mean to hi-jack just trying to get more info. for all.
Thanks Jack
68 Chevy Long utility bed.
Now swb/Bagged
Soon to be 468 (Maybe 496) BB/Turbo 400
action is offline   Reply With Quote
Old 08-26-2007, 09:41 PM   #10
jlaird
jlaird's Avatar
action, this thread may help you:
http://67-72chevytrucks.com/vboard/s...riveshaft+loop
Old 08-26-2007, 10:38 PM   #11
action
Active Member
action's Avatar
Thanks, I read that whole thing and the only # I found that would help me was 7" from bottom of frame to bottom of floor. Only problem is I have 8" from bottom of frame to top of stock drive shaft loop Of coarse my cab is on the ground, That is why I ask.I guess I will have to take out my tape and do some math.I think my body mounts are long gone, Anyone know how tall they are? Trying to get all the welding done before I put the cab back on.
Thanks for the help.
Jack
Now swb/Bagged
