Old 02-23-2008, 11:00 PM   #1
justincasey57
Is my truck a true 4x4???
I was wondering how I can tell if my truck is an origional 4x4 truck?? I've heard you could tell by the rivets in the front leaf spring hangers and I've also heard of other stuff.Can anyone help me with this?? thanks
justincasey57 is offline   Reply With Quote
Old 02-23-2008, 11:18 PM   #2
Burt4x4
Burt4x4's Avatar
Re: Is my truck a true 4x4???
Your vin number will tell you
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-23-2008, 11:26 PM   #3
justincasey57
only bad thing is a tree fell on the original cab so this cab is different so I dont know if they changed the vin plates or not.or is there a vin# on the frame?
Old 02-24-2008, 02:53 AM   #4
vtblazer
vtblazer's Avatar
Why are you wondering?
Something seem wrong with it?
vtblazer is offline   Reply With Quote
Old 02-24-2008, 03:09 AM   #5
Are your hangers riveted or bolted?How about the crossmembers?The frames taper in behind the rear axle.Does the serial number start with a "K"?If it a`72 does it start with "CK"?The frame# is left side top of rail back of engine about under the cab.
Old 02-24-2008, 03:09 AM   #6
Yukon Jack
Yukon Jack's Avatar
What year is it and can you shoot a few pics of the undercarriage so we can see if things look factory?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is online now   Reply With Quote
Old 02-24-2008, 03:18 AM   #7
justincasey57
the hangers are rivited on.dont know about the crossmember the truck is in the shop right now but I remember seeing the rivets in the hangers. the cab vin# isnt the origional vin#the origonal cab had a tree fall on it so the guy i got it from put a new cab on it and I dont think he changed the vin plates.I'll try to get some pic's of it when I go back up to the shop monday.
Old 02-25-2008, 01:03 AM   #8
79oldj
Vin number should be on your title. Sounds factory to me if the hangers are riveted on. I dont no anyone who has a hot rivet setup to put them back on to a factory look.
79oldj is offline   Reply With Quote
Old 02-25-2008, 01:18 AM   #9
justincasey57
no title either just bill of sale
Old 02-25-2008, 02:32 AM   #10
vtblazer
vtblazer's Avatar
Are you going to be able to license it where you live without a title?
Old 02-25-2008, 03:08 AM   #11
see ten
WTB this ad
see ten's Avatar
In Georgia it's No Title......No Problem. They don't even want to issue a new title if your vehicle is more than 14 years old.
see ten is offline   Reply With Quote
Old 02-25-2008, 03:36 AM   #12
vtblazer
vtblazer's Avatar
Same as here in VT.
Bill of sale is all we need.
Old 02-25-2008, 04:16 AM   #13
shilo
shilo's Avatar
Originally Posted by vtblazer View Post
Same as here in VT.
that is fantastic. Here in colorado you gotta jump through hoops of fire to get a older vehicle titled. Outta state ones at least.
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 02-25-2008, 07:32 AM   #14
79oldj
Must be nice in Illinois they have a coronary if you do any modifications such as a cab change 2wheel to 4wheel conversions. In order to get a title for one of my older projects we had to have a rebuild liscense fill out 90 pages of paperwork and a state inspector went through it with a fine tooth comb making sure every little nothing detail was right. I am a lot more leary of changing cabs out after all the bs in Illinois.
Im ready to move to Georgia.
Old 02-25-2008, 10:13 PM   #15
us111
hello,when i had my cab off of my 76 k-10 the vin was stamped on the passenger side frame rail,just about where you could c it thru wheel well.
us111 is offline   Reply With Quote
Old 02-26-2008, 07:12 AM   #16
usdabeef
Here's my 72 c-10 converted to a 4x4. 383 stroker, 3" body, 4" suspension. Should have seen me trying to get this titled in Utah. Incorrect vin # on title from state of Virginia. But it's on the road and doing just fine now.
usdabeef is offline   Reply With Quote
Old 02-26-2008, 08:32 AM   #17
justincasey57
what size are those tires? 35's??
Old 02-26-2008, 09:03 AM   #18
usdabeef
they are 35's
Old 02-26-2008, 09:08 AM   #19
dinotruck68
dinotruck68's Avatar
man u guys are freakin lucky!! the guy i bought my truck from never signed the title over from the orig. owner...ive tried to contact him but i think he died.. so im gonna hav to forge his signature
dinotruck68 is offline   Reply With Quote
Old 02-27-2008, 05:49 AM   #20
Truck Hippy
Truck Hippy's Avatar
I'm not saying factory or not with out more info (pics) but a lot of blazer frames got swapped under these trucks. Depending on how good the cut/welds are, these can pass as "factory" 4x4's.
Truck Hippy is offline   Reply With Quote
Old 02-27-2008, 08:55 AM   #21
OldCreek
OldCreek's Avatar
2wd frame?...... look at the wheel well arches on the frame. I believe the 2wd frames will have holes/cutouts where the original arms would have bolted into. These are large 1 1/2" (approx) cutouts and there will be indentations also.
IMHO.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-02-2008, 08:03 AM   #22
Truck Hippy
Any luck getting some pics or more info??
Old 03-02-2008, 08:35 AM   #23
BurnoutNova
BurnoutNova's Avatar
why would a blazer frame be put under a truck? blazer frames are shorter, even shorter than swb trucks and the work involved in lenghthening the frame would make it unrealistic
it would be much easier to just swap all the suspension parts over and bolt them to the truck frame
BurnoutNova is offline   Reply With Quote
Old 03-02-2008, 08:44 AM   #24
Truck Hippy
Putting a blazer frame under a 2wd is alot easier than you may think. The frame is shorter but you can chop up a lwb frame and add it without much work. Its done alot, around here anyway.
