Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-14-2008, 01:57 PM   #1
kwhite4
Junior Member
kwhite4's Avatar
Fuel pump pressure
I have a aeromotive drag pump setup and the pump has a bypass , I was told to set it at 30 psi but it caused the front regulator problems so i dropped it to 20 and it seems to be better.
Do any of you guys have this type of setup and what psi do you run from the pump ?
Front reg is at 8 psi .
thanks
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
Old 07-14-2008, 03:48 PM   #2
regan wilson
regan wilson's Avatar
Re: Fuel pump pressure
I have been running a BG400 for nine years . I have ran them at 30 and as low as 22 . BG recomends 24 I believe for my pump . I'm sure with the volume of your pump you should be fine .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 07-14-2008, 10:24 PM   #3
kwhite4
Junior Member
kwhite4's Avatar
Thank you sir.
I had to rebuild the carb regulator because of a bad O ring and had a heck of a time getting the right part. Guess Aeromotive doesnt have many problems with their stuff.
Anyway thanks for the info.
Keith
68 GMC
565 BBC
9.85@135.00
Old 07-14-2008, 11:21 PM   #4
71Dragtruck
71Dragtruck's Avatar
I have a A1000 pump with a return reg set @18psi, then out to static reg for my N2O set @6.25 flowing, and another static reg for my carb set @7.5.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
