Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-20-2008, 01:43 AM   #1
1970chevy
trans brake
just wondering if any body out their has install a transbrake in a th400 how hard is it do you have to pull the tranny out i just pick up a b&m trans brake with rev valve body trying to find some good pictures of instilling it b&m gives crap of instiction
1970chevy is offline   Reply With Quote
Old 07-20-2008, 10:31 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: trans brake
There is more to it than just bolting in a valvebody. At least to make it survive there is. If your not familiar with the whole scenario I'd HIGHLY suggest you take it to a good trans shop and have the trans built for the brake. Most of the stock components will survive only a short time under the rigors of a transbrake launch.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-21-2008, 06:13 AM   #3
PA-IndianRider
PA-IndianRider's Avatar
Re: trans brake
All of the "drag race" friends I have have told me the same thing. Let a PRO handle it.
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 07-21-2008, 02:37 PM   #4
regan wilson
regan wilson's Avatar
Re: trans brake
There are too many modifications to be done inside . It has to come apart . I run a Hipster brake . Nine years ago when I put my truck back together I did alot of research on this and one of my friends builds my transmissions . We have gotten it to where it survives pretty well . We usually tear it down once a year . Usually we replace a bushing or two maybe one or two clutches and steels . It is amazing how much stock TH400 parts can take . I can tell you alot of little tricks that will help it survive . Three good ones are, drilling out the center support bolt so more fluid can go to the second gear clutches , using a stock type wave plate in the case for second gear , and putting a good cross hatch on the sprag surface everytime you have it down .(these are for sprag survival) . Another important thing on a TH400 is high gear clutch clrearance ! Dont be afraid to put 100 to 110 thou of clearance in them . The reason for this is when the tranny is in low gear those clutches are turning 1.5 times engine speed backwards .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 07-22-2008, 08:10 PM   #5
1970chevy
Re: trans brake
thanks
Old 08-16-2008, 06:48 PM   #6
Ford Assassin
Ford Assassin's Avatar
Re: trans brake
A buddy of mine tried the DIY route, ended costing more in the end.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 08-18-2008, 02:58 PM   #7
Rodms
Rodms's Avatar
Re: trans brake
Need to take it to someone that knows how to build racing trans so you won't tear up all the other stuff
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-20-2008, 01:16 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: trans brake
Just took the glide in to the shop for bell housing change and freshin up . Grand total $150 . Not worth messin with in my opinion .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
