Old 03-25-2009, 01:22 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Brake fluid recommendations.
I have some Valvoline synthetic Dot 3-4.
Just wanted to ping you guys on what you found to be the best for our trucks.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-25-2009, 04:13 PM   #2
Willy Prost
Re: Brake fluid recommendations.
I use ATE.
It is standard on Porsche. I want to believe it makes the truck stop faster (hahaha).
The ATE fluid does have a higher boiling point and additional moisture inhibitors than other standard brake fluid (even more inhibitors than Castrol LMA).
If you are flushing old fluid out, ATE has both a regular gold/brown color and a blue color brake fluid. Using alternate color fluid makes it easier to tell when you have finished flushing out the old brake fluid.
I got mine locally but here is a url from Tirerack for ATE
http://www.tirerack.com/brakes/ate/a...e200_amber.jsp
Willy Prost is offline   Reply With Quote
Old 03-25-2009, 05:32 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
fresh DOT3 is all you need. The stuff is designed to absorb water for a very good reason, and with the extreem temerature differences you have there, it's somewhat important.
Old 03-25-2009, 05:39 PM   #4
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
yep... Dot 3 is fine. The higher the Dot the more heat it can take. Bikes use Dot 4 or higher.
EDIT: any bike i have seen that is...
LOW DOUGH is offline   Reply With Quote
Old 03-25-2009, 07:34 PM   #5
Sport/Truck
Sierra Grande Club
Is the 3-4 synthetic any good then? I guess it's for both?
s/t
Old 03-25-2009, 07:45 PM   #6
truckdude239
truckdude239's Avatar
yup ti will be fine
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
