292 engine problem
I’m facing problem with the engine, when I hit the gas to the end and release I hear a strange sound like (rererererererrererererererrerererererer)can some one help me to find out what is this sound, where is it come from.....
![]() Join Date: Jan 2007
Re: 292 engine problem
manaul or automatic transmission and how old is the engine?
automatic th400 with NP208, i have no idea how old is the engine, the head is not integrated.
BAD BOW-Silverado XST
Where is the sound coming from? Can you make a better sound of it?
the noise appear when i wide open the throttle and close it, the noise last few second 3-4 seconds till the engine calm, when opening the throttle slightly i do not hear that sound.
![]() Join Date: Oct 2006
Does it happen when you turn the steering wheel? Do you have power steering? Check your tranny fluid also.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Check the u-joints.
thanks guys for the help.... i'll try everything on week end
yesterday i checked everything with a friend, we did not find any thing wrong. but my friend find the sound coming from harmonic balancer, when he removed it he find that the grove is damaged and need to replace the harmonic balancer.
what choices do i have for such balancer would the small V8 engine fits my engine? it 292 parts are rarely to find, where i'm from |
Last time I was in your area, there were tons of Chevy sedans running around. Maybe it's time to drop a small block into your truck. Parts will be more available.
after removing the engine we find the problem. first problem is with the harmonic balancer was not set tight due to a crack in the center......
![]() the second problem is with the flywheel, because the harmonic was not set tight it cause a vibration and that vibration affect on the screw on the flywheel and make them to lose......al ![]() |
