How about some pics of your S10 conversion @ ride height
For those of you who have completed your finished ride height on your S-10 conversion can you please post some pics of your trucks at ride height? If you can also include any chassis mods, rim & tire sizes, and the height the body sits from the frame it would be greatly appreciated.
_____________________________________________ Thanks, Garrett ![]() My 1950 GMC Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=351867 My 1950 GMC Photobucket Account: http://s565.photobucket.com/albums/ss95/1950GMC/ Last edited by 1950 GMC; 12-18-2009 at 04:27 AM. Reason: Spelling |
Re: How about some pics of your S10 conversion @ ride height
here is my 48 gmc it is bagged on a 87 s10 frame so the ride height changes depending on the road hahaha ![]() |
That is what I hope mine turns out like. What is your suspension setup?
s10 bags and cups and drop spindles in front and 2 link in rear with bags on the bars. rides great
got any pics of the rear suspension?
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
i'm fixing to take to bed off to finsh it up. i take some pictures when i get it off aod post them for you
Mine is almost complete except for 18"'s on front and 20"'s out back. But this is how mine sits now with 16" extreme wheels. The ride height should be almost the same after checking the tire circumfrance. The body sits off the frame a 4X4 block +/- 1/2 inch measuring from floor pan to frame. Front has 2 inch spindles and 1 inch dropped coils, back has second spring removed and 2 inch blocks.
1952ssr, what did you use for wheel spacers on yours?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
I've got 2 inch spacers front and back.
How wide are the extreme wheels? I had to do 1" spacers on my 4wd s10 rear to get the 15x7 (3.75"bs) wheels to clear the bedsides with no tubbing, and I'm looking at what I should do on the front. Thanks!
They are 16 X 8 with zero offset.
Mines 4" off the ZR2 frame - no wheel spacers up front - 1 1/4" spacers in the rear to make the stock 31" tires fit
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=372267 49 4x4 build 51 Willys frame off beer getter. |
1952ssr, Did I read that correctly 4" +/- 1/2" off the frame? Thanks for sharing.
_____________________________________________ Thanks, Garrett ![]() My 1950 GMC Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=351867 My 1950 GMC Photobucket Account: http://s565.photobucket.com/albums/ss95/1950GMC/ |
#15 |
I didn't get to the shop last night, was shopping for last minute gifts. Within the next few days off I'll get some pictures and measurements. I'll get back with everyone next week, I don't have the net at home.
MERRY CHRISTMAS |
#16 |
Registered Chevy Owner
Heres mine. Nothing fancy done to it. It's stock ride hight for the s10. I think the back of the front fender is about 6" off the ground.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#17 |
Thanks for sharing everyone. Nickp51chevy how far off the frame does your body sit?
#18 |
Nickp51chevy, I just read your build thread 3 1/2" thanks.
#19 |
Well got in 10 hours of work on the '51 Saturday. Here are some pictures to get a better idea where my cab sits. About 5-5 1/2 inches off between frame and floor pan in the battery mounting hole. Notice in the second, hard to see it but there is a 3/4 piece of square tubing between the top body mount cup and original cab channel. Those brackets were made using the left over frame cut from the back and a s10 body mount bracket.
#20 |
Others: second is from bottom of back of cab to frame about 3 1/2
#21 |
AD Addict
Not a great pic and wheels have changed but:
![]() Stock S10 suspension with 3" blocks in the rear. 2" spacers all the way around, S10 4x4 rear end. Body sits about 5" off the frame (4" blocks and 1" stock S10 body mount). Rear cab mounts are stock '54 shackle mounts. 327/NV3500 5 speed. About 8-9" to the running board bottom. Last edited by Dan Bowles; 12-30-2009 at 04:14 PM. |
#22 |
My '52 is mounted 5" off the frame, S10 Xtreme (ZQ8) stock factory lowered front and rear suspension, '79 Camaro rear end, 15x8 Corvette rally wheels, 245/60/15 tires with 1.5" spacers in front, 350 crate motor with 700R4 trans.
#23 |
Member of the longbed union.
trucks look good guys
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#24 |
Moderator
![]() Join Date: Jul 2006
Way to keep this thread going! I've got to have one of these trucks!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#25 |
FiftyTwo, Nice! Your truck is awesome looking. I was going to do the same thing with my gas filler neck also, but I didn't want to chance screwing up my bed side so I didn't. Instead I put a wood box in the back of the bed. Check it out in post number 16.
LEEVON, you don't want one of these truck. ![]() ![]() ![]()
