![]() Join Date: Jul 2007
C notch questions
I am starting my C notch (weld in) in the next few days and am wondering if there is concern for supporting the rear portion of frame behind the axle to prevent warping/misalignment. If I do need to worry there what the heck can ya do to support it while installing the notch? This is on my 72 c-10 short super build. It has rear coils.
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
Re: C notch questions
Oh ya it is currently just a chassis w/o body on it. Thanks Phil
Redefining LowBudget
I would just cut it and weld in your notch....if you are woried then tack weld a piece of angle iron on top of the frame rail that wil stop it from doing anything funny....just be sure to put your jack stands in front of the axle
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Signals in the bumper.
Weld the sides and top of the notch to the frame first. Next, cut the frame out from the notch.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
What he said, just notch the sides of the frame slide the notch in. Make sure you have a good tight fit, weld it up and then cut the frame away in the middle of the notch. That way there is very little chance of getting anything crooked or drooping.
he did say C notch didn't he?? I guess this falls into that catigory of not clear is it a 2" or 10??
I don't see a need for extra support for a C-notch. But if its a step notch, that's a whole other animal.
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
thanks for the answers. I just went for it and I dont feel like it moved any. Here is a pict of whats done so far.
I'd like more info on that sway bar and how well it clears with the notch??
The notch on the dr side is complete. The sway bar is an Aadco and is for an ~82-93 camaro rear. I used a thread from this site to install it and it looks great. The sway bar will have a close clearance on the rear facing horizontal portion at the rear of the notch. I havn't compressed the suspension enough to see what it will really do but will soon. I intend on pivoting the horizontal portion angled downward maybe *15-20 to help clearance. It should be fine. I will get some picts of the clearance tomorrow when I start the other side.
