Old 03-30-2010, 10:43 PM   #1
primetime
primetime's Avatar
vaccuum booster with 1barrel carb
is this possible. my truck is a L6 with 1 barrel carb. 250ci. the truck has disk brakes but i'm looking to upgrade to power disk near future. i'm going to get a kit that has drop spindles. so, can a 1 barrel carb produce enough vaccuum to operate a power brake system?
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 03-30-2010, 11:08 PM   #2
PDW HOTRODS
PDW HOTRODS's Avatar
Re: vaccuum booster with 1barrel carb
The engine makes the vacume, need to find or install another vacume port somewhere.
PDW HOTRODS is offline   Reply With Quote
Old 03-30-2010, 11:25 PM   #3
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
find or make (drill and tap) a port in the intake manifold?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-30-2010, 11:34 PM   #4
SCOTI
SCOTI's Avatar
Very possible as they said. I had power discs on my 68 w/a 250/3spd.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-31-2010, 06:37 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Every inline 6 I have ever seen had a fitting on the intake manifold below where the carb mounts just for the brake vacuum fitting. GM sold them with power brake option forever. You're good to go.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-31-2010, 12:51 PM   #6
primetime
primetime's Avatar
but was it vaccuum booster or was it hydroboost?
Old 03-31-2010, 12:53 PM   #7
primetime
primetime's Avatar
but was it vaccuum booster or was it hydrobooster
Old 03-31-2010, 12:53 PM   #8
Tx Firefighter
Vacuum. They even made special offset air cleaners so it would clear the brake booster.
Here is my old truck with one on it.
Old 03-31-2010, 12:54 PM   #9
primetime
primetime's Avatar
i will double check the area when i get off work today. thanks
Old 03-31-2010, 06:17 PM   #10
SCOTI
SCOTI's Avatar
Vacuum boost w/discs all swapped over. I couldn't find the offset air cleaner like TxFirefighter had so I used a smaller aftermarket set-up for a 1-barrel carb.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-31-2010, 09:25 PM   #11
primetime
primetime's Avatar
i looked at mine awhile ago and couldn't come up with a vaccuum source, yet. i did however find lots of leaks. s#!t. can someone post a side picture of their L6 so i can see the area they are using?
Old 04-01-2010, 12:30 AM   #12
Chevydude56
Chevydude56's Avatar
Picture of my 292 , I think the power power was added .
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 04-01-2010, 10:22 AM   #13
primetime
primetime's Avatar
wow. you just made my engine look like garbage. one day it will be nice as yours though.
Old 04-01-2010, 11:29 PM   #14
Chevydude56
Thanks . it's a "spray can rebuild" I took the manifolds off to replace the gaskets and thought I would sandblast and paint them while off... then had to clean the block and paint that...took off valve cover sandblast and paint, all with spray cans .one thing just led to another. Found the air cleaner at local pick n pull more spray can paint . Here's the before
1964 Chevy II wagon
1967 GTO
1978 Chevy Van 30
Old 04-02-2010, 03:40 AM   #15
DWright
Shlong Bed Club
DWright's Avatar
old setup...
"If it ain't broke, hit it with a hammer, then fix it.."
DWright is offline   Reply With Quote
