Old 03-08-2021, 07:32 PM   #1
roll_the_dice
roll_the_dice's Avatar
Stepside Spare tire hanger
I am working on my spare tire hanger. I have an OEM hanger with the 6 lug pattern. These are the 2 options I see to make it work for a 5x5 lug pattern...
Cut all 3 studs off and weld a 7-8" circular disc to the front with 3 new studs in the correct pattern
OR
Leave the face OEM cut the 2 bottom lugs off and weld 2 new studs in the correct place on the OEM face..See pic.
Which do you think would be a better solution? I am also open to other suggestions. Thanks!
roll_the_dice is offline   Reply With Quote
Old 03-08-2021, 09:11 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Stepside Spare tire hanger
I lean toward option 2. It keeps it simple, more original, and less chance for rust by avoiding a pocket between 2 separate pieces of metal.
AcampoDave is offline   Reply With Quote
Old 03-08-2021, 10:37 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by acampodave View Post
i lean toward option 2. It keeps it simple, more original, and less chance for rust by avoiding a pocket between 2 separate pieces of metal.
+1
Old 03-08-2021, 10:54 PM   #4
SkinnyG
SkinnyG's Avatar
I will be cutting/relocating studs on mine, but using the existing plate.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 03-08-2021, 10:58 PM   #5
Getter-Done
Getter-Done's Avatar
What about a thin wheel spacer adapter?
Use cap screws like this vvv
link: https://www.fastenal.com/products/details/2124365
And lugs pressed in?
example only:Name:  spacer.jpg
The early bird gets the worm,
84 Chevy K-20
Old 03-08-2021, 11:32 PM   #6
roll_the_dice
Originally Posted by The Rocknrod View Post
+1
I thought about the possibility of rust about the same time you posted. I do like the idea of it looking OEM...the only time it wouldn't look OEM though is if the wheel is off...but I would know. Thanks!
Old 03-08-2021, 11:33 PM   #7
roll_the_dice
Are you going to use threaded rod or drill into the face and weld bolts from the back side?
Old 03-08-2021, 11:34 PM   #8
roll_the_dice
Interesting idea...I did find this but pricey...
https://www.ballisticfabrication.com...mounting-plate
Old 03-09-2021, 12:11 AM   #9
Getter-Done
Yes that is the Idea.
Do you have a Drill press or hand drill?
You can make this yourself
84 Chevy K-20
Old 03-09-2021, 01:25 AM   #10
SkinnyG
SkinnyG's Avatar
I'd likely weld bolts from the back side.
I also need to alter the mount slightly, to fit the long step brace to my short step bed, but that's not your issue here.
Old 03-09-2021, 10:09 AM   #11
roll_the_dice
I have both, but I think I am going to cut off the 2 bottom studs and weld 2 new studs or bolts on. I think it will be cleaner in the long run, plus cheaper. Good suggestions though! We were thinking across the same lines!
Fortunately, I don't have to alter mine! Since I am a beginner at welding (literally) I think a bolt through the back and welded on will be simpler and easier. Thanks!
Thanks for the suggestions everyone and helping me think this through! I'll try to take pictures of the finished product when I am done and post here or at the very least on my build thread.
