rear disc
has anyone converted their rear end to a rear disc set up i need all the info that i can get thanks
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 ![]() ![]() |
![]() Join Date: Oct 2009
Re: rear disc
I'm currently converting mine this week. I purchased the 4 wheel disk kit w/ cross-drilled/slotted rotors from Classic Performance Products. Will updated with pics and info when done, however will be AWHILE before it sees the road.
What specific info you looking for? Vendors, parts, instructions, etc...? Best of luck.
Justin 71' C10 SWB 00' Dakota R/T 05' Z-71 Silverado 16' Z-71 Silverado Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904 |
CopyWritten
Re: rear disc
What lug rear end are you running? I bought a conversion kit from kaptinfab here on the board that utilizes 95 impala ss rear disk breaks. I just installed it today! You can do the entire conversion for around $200
Re: rear disc
Another vote for CaptianFab. I decided to use the F-Body calipers to keep an e-brake. Gotta have it for inspection here in TX. Do a search in the suspension forum. There are several options. Many have done it.
CopyWritten
Re: rear disc
because we have sooo many hills here in TX that if we didnt have an emergency brake we would be in for it!
#6 | |
Re: rear disc
![]() ![]() 2000 Ford Powerstroke (daily driver) |
Re: rear disc
i wanna keep the e brake and i need instructions vendors and all tha good stuff
Re: rear disc
if you have 6 or 8 lug wheels.....use the factory rear disc setup from a 2000+ gm truck. millions of dollars invested in r&d - not a mix of parts, the e-brake setup is better (rugged separate drum instead of in the caliper), and replacement parts are available at the local store. i love aftermarket parts (poly bushings, braided brake hoses, etc), but if there is a factory part that is comparable (or better) i automatically go that route.
One foot in front of the other
![]() Join Date: Aug 2008
Re: rear disc
CaptainFab
Re: rear disc
i have a 72 5 lug rear
#11 | |
Re: rear disc
What part number did you buy? Do you have a link? thanks AL
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Re: rear disc
this might help
http://www.classicperform.com/6092chevtrk.htm#42 i might recommend these brake kits too http://www.mcgaughys.com/newproducts.html |
Re: rear disc
Here is the part # from CPP I used: 6772FRBK5 along with option 3 (Crossed Drilled & Gas Slotted Rotors) & option 5 (powder coated calipers).
Link also: http://www.classicperform.com/Store/.../6366FRBK5.htm Hope it helps!
chevy truck fan
Re: rear disc
i bought my kit from CPP as well. overall i would recommend the kit..... but the instructions leave a bit to be desired. i wish they provided more detail. i feel the update is worth the money, no matter which one you choose. good luck!!
P.S. i have a '72 chevy 5-lug rearend.... |
#15 |
Re: rear disc
I put disk brakes on the rear of my 69 C-10. The calipers have emergency brakes. One side emergency did not work. The company is shipping me another caliper. No charge for shipping. The truck stops real good, but the pedal is a little spongy. I think disk braked are a little spongy.
