Old 03-05-2010, 12:49 AM   #1
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
hd leafsprings
those of you that have lowered hd rear leaf setups in the rear. how many leafs did you leave in the rear if you removed some. I still have 5 leafs after removing a couple. can i remove anymore and still be alright? i want like another 1-2 inch drop in the rear. I have a pretty mild 355 in it and when i get on it all it does is spin the tires, so i dont have any axle wrap yet.
staggerd86c-10 is offline   Reply With Quote
Old 03-05-2010, 01:00 AM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: hd leafsprings
I think it depends more which ones you remove. Some of them add to the spring rate quite a bit more than others. Seemed like the ones up near the top did less than the ones near the bottom when I took leafs out of mine.
I started with 8, took out the huge overload and one of the upper springs that didn't seem to be doing much and ended up with 6. Does perfectly fine even with the bed filled and it goes over bumps a lot better.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 03-05-2010, 01:01 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: hd leafsprings
I had 3 left out of 8 didn't have any problems
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-05-2010, 03:38 AM   #4
staggerd86c-10
Re: hd leafsprings
only 3 and a flipkit?? how low did your truck get when you did that? i dont have a flip kit but i want my truck a bit lower, so if i remove 2 more leafs how much drop should i expect?
Old 03-05-2010, 01:11 PM   #5
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: hd leafsprings
Well if those 2 leafs are a total of an inch thick, you will get that and then a little more for the reduction of spring. That is my thought anyway.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-06-2010, 09:42 AM   #6
staggerd86c-10
Re: hd leafsprings
so if i want like an inch or inch and a half try by removing one at a time? sounds like the right way to do it i just dont like taking things apart more then i have to.
