Junior Member
Exhaust manifold question
Does anyone know what these fit? I assume 67-72.Are they aftermarket or GM?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 05-25-2010 at 02:14 PM. |
![]() Join Date: Apr 2010
Re: Exhaust manifold question
SBC...probably a 327ci or 350ci motor.
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
Junior Member
I may have found the answer on the Dorman exhaust site. Can some one confirm this is a 69-72 NOS exhaust manifold?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#4 | |
*** That's interesting ***
I don't have a parts lookup or a casting number book with me right now. So someone else will have to look that up for you. But by sheer looks alone, it appears to be correct.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
Hand Crafted C-10
![]() Join Date: Aug 2006
I find it odd that GM isn't stamped on it.
My '68 manifold has the assy bracket but, other than that, you will notice dimples near the bolt holes and the GM logo stamping. |
Junior Member
I will look at my 69 tonight. I said NOS because if you see it in person it appears to never have been on a vehicle. I also have this one which is definately aftermarket.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 05-25-2010 at 04:13 PM. Reason: add info and pics |
It might be a repop. I think the 'rams' look a little too smooth and fluid. The originals were very rough castings with casting marks pretty evident. I don't know for sure though.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Junior Member
I also got these and have no clue what they are from?
At one point, GM switched from mounting the belt accessories to the manifolds to mounting them to the bosses in the heads. I think this change took place in the late 60's. I'll look it up in my books at home to give you the exact date. But I think the ones in the 2nd pic are from a much older SBC car (or truck?). It also appears that you have a spacer on the top manifold (2nd pic) which is for the valve that would close when the engine was cold. Often times these valves seize up and are replaced with a spacer. (Can't tell if yours is only a spacer or a hollowed-out valve)
For a 69+ truck, I would say no to the 2nd pic for sure. I know by '69 those accessory mounts were all but gone on the manifold except for MAYBE the 'Vette, and even that I'm not sure without my book.
Watch out for your cornhole !
![]() Join Date: Jun 2003
There's one little detail in this picture that makes me sure it's aftermarket...
#11 | |
Shawn
I was just fooling around. Thankfully it's on the inboard side of the unit though. I don't believe I could stomach seeing the word "China" on the side of my engine every time I opened the hood.
#13 | |
C-10 Club Member
Where ![]() ![]()
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
#15 |
Junior Member
I know that one is Kev but what about the other with a GM part number.
#16 |
I can't tell if it's a proper number for 69-72 trucks, but it will work great regardless of the number.
#17 |
Junior Member
I bought a couple of trucks and a bunch of parts and these were included. I am probably going to sell them and did not want to misrepresent the item. What do you think is a fair price if we consider them both repops?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 05-25-2010 at 04:51 PM. Reason: punctuation |
#18 |
You can research them through Summit. They sell Dorman aftermarket manifolds for these old trucks. That would give you a new price so you can figure what your price would be from there.
#19 |
Junior Member
For a pair from Summitt to your door would be about $250. I was wondering what I could possibly get for them on the parts board? I know everyone here is cheap.
#20 | |
72 Cheyenne Super 80 Silverado Blazer 2wd |
#21 |
I just checked my book from the first set of pics. 3932469 maps to LH 69-70 350,400ci small block, passenger car, no AIR. Dipstick indent is the little valley next to the "695" number, so this would have also been a driver's side dipstick car.
They will work correctly on a truck since trucks 67-72 need a curved dump for best fit. They should have a GM logo, so need first pics are repops. And we all know what the ones from China are all about.
