Old 07-22-2010, 03:24 PM   #1
Matt Man
Matt Man's Avatar
removing paint off door panels & EGR?
well when i got my truck i wanted to change the interior to black so i painted my door panels black is there anyway i can just remove the paint off them? or can repaint them better so it wont flake off in some spots.
Also did my truck come with a EGR? 86 chevy c30 10,000lb GVWR Carb 454, no cats , just a smog pump. Truck was sold in california. And i live here if that matters.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 07-22-2010, 03:30 PM   #2
ERBSIX
ERBSIX's Avatar
Re: removing paint off door panels & EGR?
I would remove all the paint.
A dual action sander from harbor freight is like $20.
Then primer, and repaint.
Update: Crap, just re-read and caught you said "door panels" which means the interior (plastic) ones, right?
In that case a good high-grit sandpaper to take the paint down and get a specific plastic rattle can paint. Follow the instructions.
EGR: Almost positive something that new would have had one.
78 Silverado 1/2 Ton LWB (restore)
78 Silverado 3/4 Ton LWB (parts truck & practice - eventually a work horse)
My Build thread: http://67-72chevytrucks.com/vboard/s....php?p=4082128
Ellis Benus - Web Design Columbia Mo & Google Fan Boy!
ERBSIX is offline   Reply With Quote
Old 07-22-2010, 03:32 PM   #3
Matt Man
Matt Man's Avatar
ya. i was like umm im not sanding them...
Old 07-22-2010, 03:32 PM   #4
ERBSIX
ERBSIX's Avatar
You gotta sand them to get a quality bond. Especially on plastic.
They will keep peeling if you don't.
Old 07-22-2010, 03:56 PM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
You can't sand texture. If it has the factory panels still on it, then there is texture.
Easiest thing to do is probably get the panels off, strip off all the cloth and such where all you have is the hard plastic panel. Try on a small area, just to be sure, but lacquer thinner on a rag should take off all the paint, quickly too. Just make sure you get every last bit of it off. Then clean them with soap and water, and then with degreaser, then with wax and grease remover. Then do it again like 20 times. They can simply not be clean enough.
Once cleaned and ready to paint, get some SEM Color Coat spray bombs in the color you want. They also make an adhesion promoter you can use that helps aid in the paint sticking. I actually prefer Bulldog adhesion promoter (Kleanstrip is the brand), had excellent luck with it over the years.
Any store like O'Reillys should sell the SEM Color Coat, and have a color chip sheet to look at. If not, you can view it online:
http://semproducts.com/images/Users/...0CC%202008.pdf
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 07-22-2010, 07:29 PM   #6
Matt Man
Matt Man's Avatar
if i use the thinner will it leave them looking funny? i would just like to have blue ones thats the way they came.
Old 07-22-2010, 07:40 PM   #7
RandyP
RandyP's Avatar
Once you wipe/clean them with thinner, they will have a significant white haze on them no doubt. Try it on a small area down low first, see what it does. I have been able to clean panels up and then wash real good with soap and water and apply armorall and shine them up.
Just do not armorall them if you are going to respray them, or even think you are going to respray them. Armorall is paints worst enemy.
