Old 11-12-2010, 02:10 PM   #1
gary2232
Spare Tire Size
I have a 72 K-10 with 32x11.5x15" tires. If I use a 31x10.5x15 tire as a spare will it cause and damage to drive train??
gary2232 is offline   Reply With Quote
Old 11-12-2010, 03:27 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Spare Tire Size
As a spare, no problem.... but it could be an issue if you bolt it on & run it...
Sorry, I couldn't resist. There's about a 3.2% difference in diameter (or circumference), and I wouldn't use it on the rear axle, especially if you have any kind of limited-slip back there. It might be okay on the front (but only in 2WD, and assuming you don't have a full-time system) for a short time, but that's about it.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-12-2010, 05:26 PM   #3
gary2232
Re: Spare Tire Size
Ok thanks for the response. I sure hate putting that big a tire up in that rack under the bed. It is hard to get up there and lowers the ground clearance. But if I must. Thanks P.S. I like the sarcasm it keeps it fun!!
Old 11-12-2010, 06:46 PM   #4
raycow
Re: Spare Tire Size
Ya know, the spare only has to match for diameter, not width. Why not use a skinny 32" tire? Maybe something on a larger diameter (but narrow) wheel. It will weigh less and give you more ground clearance.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
