Old 01-25-2011, 04:31 PM   #1
burger
Did CCC Q-Jets Ever Appear on Squares?
Did later model square body trucks ever come with a CCC QuadraJet carb?
Thanks,
Ed
burger is offline   Reply With Quote
Old 01-25-2011, 05:14 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Did CCC Q-Jets Ever Appear on Squares?
If you mean computer controlled, I believe they did come on the last of the California Emissions models right before fuel injection took over in '87.
My '86 had what looked like a computer controlled carb, and is often mistaken for one, but it was not.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-25-2011, 05:34 PM   #3
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Thanks,
Ed
Yes... mine does, and it's a California model
and it's all dialed into a check engine light for emissions... It's silly here how the smog reg's go
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 01-25-2011, 07:02 PM   #4
83burban
got one in my 83. first year of them. also has the ESC distributor - really not a fun system to work on but it works now and will have to do till a motor swap and de-smog.
83burban is offline   Reply With Quote
Old 01-27-2011, 12:34 PM   #5
burger
Thanks for the answers!
Old 01-27-2011, 01:18 PM   #6
Malo83
Cruzzzn' Vet
Malo83's Avatar
This is on my 83 also
Uploaded with ImageShack.us
Malo83 is offline   Reply With Quote
Old 01-27-2011, 03:30 PM   #7
ironroad9c1
Master Hater
Yea if it only has the blue plug on top its technically NOT a CCC carb, That was only a plug to control the Dual volume Accelerator pump. it worked just like a regular Accl pump when cold, but after the engine warmed up the computer sent a signal to the carb to activate the Solenoid and cut the Volume of the pump chamber. then it wouldn't give as much gas when you where in stop and go type driving where you where on and off the gas alot. The two shown above have the Throttle position sensor that is the clear looking plug in front of the throttle linkage that is the easy way to tell. and those are CCC carbs.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
