It followed me home?
454 blowing blue smoke only above 3k rpm
I finally found a really cool 4*4 flatbed crew cab for work but the engine blows a lot of blue smoke but only above ~3k rpm. I took it for a test drive and through and on the highway it runs PERFECT, only blows smoke at high rpm. Owner said its been sitting on and off for a few years and once he drives it for a week or so the smoke stops? There is a little smoke on startup but not a lot, any ideas? Valve seals? rings? I did pull the pcv and it doesnt look like it is full of oil, let it idle with pcv out didnt see any smoke.
This will mainly be a big lot plow truck, and hauling small loads of rock, mulch, trailers etc... Oh the truck is an 89 tbi 454
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 01-28-2011 at 04:47 PM. |
Re: 454 blowing blue smoke only above 3k rpm
nobody?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Garage wrench
it sounds like it could be pcv, but I am no engine builder. Maybe try pming BigBlocksRule. He seems to be pretty smart with the older big blocks.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
