Old 02-07-2011, 08:17 PM   #1
xconcepts
What is it #2
So what is this? It is below the passenger tank near the non OEM fuel line coming from the top of the tank.
xconcepts is offline   Reply With Quote
Old 02-07-2011, 08:50 PM   #2
russgt
russgt's Avatar
Re: What is it #2
selector for dual tanks?
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 02-07-2011, 09:16 PM   #3
big_b
Re: What is it #2
that is the "y joint" you were asking about in your first what is it post.
like mentioned above that is the dual tank valve.
big_b is offline   Reply With Quote
Old 02-07-2011, 09:22 PM   #4
xconcepts
Re: What is it #2
So where would the lines from the drivers side tank come from? Its obviously not hooked up but I have no lines from the drivers tank.
Old 02-09-2011, 11:28 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: What is it #2
The drivers side feed lines run across the rear frame cross member where the body mounts are from the drivers side to that valve and only 1 set of lines go to the front.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-09-2011, 11:45 PM   #6
baclay9
Re: What is it #2
Your fuel filter should really be between the fuel pump and carb also.
baclay9 is offline   Reply With Quote
