Old 02-21-2011, 06:10 PM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
sending unit ground.
Found out why my fuel guage isnt working. my ground to the sendng unit is broke off. was wondering whats an easy cheap fix. i don't really want to put a new sending unit in
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 02-21-2011, 06:29 PM   #2
silvereagle07
silvereagle07's Avatar
Re: sending unit ground.
Can you repair the wire? Where is it broken at?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-21-2011, 07:15 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
If it's broken off right at the top of the sender, you can CAREFULLY solder a new ground wire onto it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-21-2011, 07:23 PM   #4
low man
low man's Avatar
just remove it and solder it back on.
87 short bed.4",6" drop sold 90chev z71 6" lift. with 35"sold 07 4x4 colorado on 31" 1971 chev blazer
low man is offline   Reply With Quote
Old 02-21-2011, 07:27 PM   #5
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
yeah thats where it's broke. good thing i picked up a solering kit a few months back. yay for tearing the bed off LOL
Old 02-21-2011, 10:11 PM   #6
madcow75
madcow75's Avatar
You could hose clamp the wire to one of your outlets. Alittle steel wool to make a good connection. I also have about 6 spares if you are running 25 gallon saddle tanks. I am not using them anymore. I am in the middle of putting 31 gallon suburban tank in. Just a thought.
madcow75 is offline   Reply With Quote
Old 02-21-2011, 10:39 PM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
it will work? yeah i just have a single side tank.
Old 02-21-2011, 11:05 PM   #8
chevymotocross
chevymotocross's Avatar
Lol, been there done THAT! But see I have an 87, with the electric pump. Was doing cab corners one day and went to start and move the truck. Nothing. Found that broken wire right at the darn tab. Fearful of gas and soldering, I took a blue electrical connector, crimped it on the wire. Then I took a small sheet metal screw, screwed it onto the sender tab. Nice and solid, hasn't been a problem since!
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 02-21-2011, 11:17 PM   #9
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
hmmmm this also sounds like a solid idea... when i get it apart i'll look at my optins! thanks for the great ideas guys!
