Old 06-03-2010, 07:30 PM   #1
niceguy678us
I need a 4x4 swb frame
I need a 4x4 swb truck frame. Let me know what you have. It can be just ta stripped frame with no running gear. Will consider a lwb frame to chop down. Let me know if you have one or know where one is.
Thank you for your time.
1970 Datsun 240Z
1972 K5 Blazer Highlander
1972 Chevelle
1959 Apache 3100 SWB Fleetside
2006 VTX 1800f
Build thread:
http://67-72chevytrucks.com/vboard/s...ght=highlander
niceguy678us is offline   Reply With Quote
Old 06-03-2010, 09:12 PM   #2
67/72junkie
Re: I need a 4x4 swb frame
I have one that is repaired.It was 68 swb 4x4 that got hit in the front.I cut under the cab and replaced front half with 71 blazer. Has reinforcement plate and power steering box with sb cradle no springs or front axle has dana 60 rear axle hd stock springs ,not sure on gear but I think 410. I would take $400 for it.I am going to Talledaga in oct if you don't find one close before then and could deliver that far.
67/72junkie is offline   Reply With Quote
Old 06-05-2010, 12:58 PM   #3
niceguy678us
Thank you Junkie, I will keep yours on the possibles list. But if I can I would like to find one closer.
Does anyone else know of one? In a field somewhere etc.?
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 06-05-2010, 02:03 PM   #4
HuggerCST
HuggerCST's Avatar
Check with La. member "Victoryauto". He's in Natchitoches and I think he still has one.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 06-05-2010, 02:55 PM   #5
Hart_Rod
Hart_Rod's Avatar
How about a blazer frame?
Hart_Rod is offline   Reply With Quote
Old 06-07-2010, 08:31 PM   #6
niceguy678us
Bump ------
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 06-08-2010, 11:39 AM   #7
trucks72
trucks72
trucks72's Avatar
I have got a rolling blazer frame with all the susp. under it. Has a 350 in it, manuel trans, and transfer case in it. $600 would but it.
trucks72 is offline   Reply With Quote
Old 06-08-2010, 11:17 PM   #8
niceguy678us
The blazer frame and the truck frame are completely different. Thank you for the offer though.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 06-09-2010, 07:57 AM   #9
trucks72
trucks72
trucks72's Avatar
All you have to do is cut the rear off the frame a little and put the bed mounts on. We did a truck a couple of years ago this way.
Old 06-09-2010, 01:24 PM   #10
niceguy678us
But the wheel base (center to center of axle) is longer on a truck than the blazer. So If I were to try and mount the bed, even with re-arranging the mounts, the wheel will be too far foreward. I would have to cut the frame and add like 10 inches or something (can't remember exactly) to push the rear frame arch and spring mounts back.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 06-10-2010, 12:12 AM   #11
trucks72
trucks72
trucks72's Avatar
You are going to cut a long wheel base to a short if you find one. You could make the blazer one longer with a little more work. I just thought it might help you out. I get some guys here from Brookhaven Ms. Is that close to you?
Old 06-10-2010, 01:29 AM   #12
niceguy678us
I'm almost on the texas border and down by the gulf in La.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 06-10-2010, 01:32 AM   #13
niceguy678us
I know someone somewhere around here has one of these frames just sitting there rusting away never to be used again. I just hope they run across this thread LOL.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 11-09-2010, 07:11 PM   #14
niceguy678us
Still looking for a lwb or swb 4x4 frame. Let me know what ya got!!
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 11-10-2010, 10:05 AM   #15
niceguy678us
bump..... Long wheel base or short wheel base, just let me know what you have I can use either one.....
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 11-10-2010, 12:14 PM   #16
70BLAZERX2
Billsbowtie should still have a 68 1/2 4x4 frame longbed..but its a long roadtrip to rosehill va... (sw va)
It was a calif truck..nice rustfree frame
70BLAZERX2 is offline   Reply With Quote
Old 11-10-2010, 03:36 PM   #17
niceguy678us
That is a really long way up there. I will send him a message anyways just to see what he has.
Anyone else have or heve seen anything closer?
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 11-10-2010, 03:53 PM   #18
my67chevytruck
Under Construction
my67chevytruck's Avatar
Ill see how much rust my spare frame has on it....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-10-2010, 04:36 PM   #19
niceguy678us
That would be awesome!! DFW is definitely within striking distance.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 11-12-2010, 11:37 AM   #20
niceguy678us
To the top again...
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 11-12-2010, 03:12 PM   #21
70BLAZERX2
ttt for you pm sent
Old 03-03-2011, 10:31 AM   #22
niceguy678us
Back looking again, previous deal fell through.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 03-04-2011, 04:32 AM   #23
jeremy zander
jeremy zander's Avatar
I have a 3/4 4x4 LWB frame for sale ..check the 67-72 trucks for sale ,,It was a tow truck I took down to the frame for my next builder project...
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 03-05-2011, 06:29 PM   #24
niceguy678us
Thank you for the referral, but I need to find something closer to me. Someone's gotta have one around here somewhere.
1970 Datsun 240Z
1972 Chevelle
2006 VTX 1800f
Build thread:
Old 03-05-2011, 06:38 PM   #25
DPowers
One foot in front of the other
DPowers's Avatar
You run the inventory on the PAP in your area?
DPowers is offline   Reply With Quote
