Anyone else have this problem with their window weateherstriping?
I got new window weatherstriping from LMC and installed it the proper way (I think), with the window all the way up there's still a small gap between the window and the weather striping. The gap is the same on both the drives and passengers side. Anyone else have this problem? the PO had already removed the old weatherstriping so I can't tell if the new went in the same way as the old.
![]() Join Date: Jan 2011
Re: Anyone else have this problem with their window weateherstriping?
Is the window up tight in the front? The tracks may be mis aligned.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
If I had to guess, I would say the fuzzie pieces in the door are keeping your window from going all the way to the top. Mine do the same thing... You may not like my solution, but what I do is pry them away from the window little while rolling them up.
X2...Sux!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
1 thing at a time is progress.
![]() I experienced the same problem last night. My window went up a little more than yous did, but the window track was hitting the outer belt weatherstrip (fuzzy). Once I pulled out a little it rolled right up. I figured it was my repop doors. I think it will work itself in because it was barely hitting. It was just enough to catch. I operated the window after each piece I installed to make sure it would work fine. The one thing I don't like the most is the window track is slightly visible once it is rolled up. Most people will not notice it. ![]()
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 05-09-2011 at 12:04 AM. |
^^^^ Your truck looks bad a$$ anymore pics not trying to thread jack sorry about your window problem maybe talk to a tint shop or window shop sometimes in the past with another type of vehicle I had which shall remain nameless the windows would get a little tacky from use and a good cleaning would help them slide better perhaps there's a product the 2 entities I mentioned would know of that also acts to lubricate the affair. Good luck.
66 C20 LWB CS 327/TH400 A/C |
#7 | |
Alan
Philippians 2:14-16 |
#8 | |
Mine does the same thing w/ the re-pop window seals. I think I'm going to just have new window glass cut 1/2" longer. I figure the re-pops are probably going to be around in the same format for the near future, and my door glass is pretty beat up anyways.
#10 | |
