Old 05-23-2011, 09:31 PM   #1
Rbcustoms
Rbcustoms's Avatar
Steering way to loose
My steering has way to much play in it, and all the steering parts are brand new and all the nuts and bolts are tight. What do I need to do to tighten it up? Also the truck is 4 wheel drive will be waiting to hear how to fix this
It's not what you buy, It's what you build
Rbcustoms is offline   Reply With Quote
Old 05-23-2011, 09:38 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Steering way to loose
define loose.. compared to the newer trucks the steering on these trucks is sloppy and loose.. its just normal for most of the trucks of this genre tho
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-23-2011, 09:50 PM   #3
Rbcustoms
Rbcustoms's Avatar
The wheel has about 1/4 play in it and thats not right cuz i also have a 80 c20 it does not have that much in it of play in it, i know there is play in these trucks but not this much
Old 05-23-2011, 10:03 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
There's a stud sticking up on top of the steering box cover plate with a lock nut on it, Loosen the nut and turn the stud with a allen wrench inward 1/4 turn at a time until most of the slop is gone. Keep your hands off/away from the steering wheel when you start the engine after adjusting, If you go too far in with the adjuster the wheel could snatch around as the engine fires and take a finger/thumb out.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-23-2011, 10:07 PM   #5
Rbcustoms
Rbcustoms's Avatar
thanks ill go try that right now and see what it does
Old 05-23-2011, 10:09 PM   #6
72lb4x4
Be careful adjusting it that way and test by turning lock to lock after each adjustment. You may find the slop is gone, but it binds when turning.
72lb4x4 is offline   Reply With Quote
Old 05-23-2011, 10:55 PM   #7
thun
thun's Avatar
Here is a thread where guys replaced the rag joint with Jeep XJ steering shaft. Never did it but they said they had great results...
http://67-72chevytrucks.com/vboard/showthread.php?t=382088
86 C20 2wd with 454 and Turbo 400
thun is offline   Reply With Quote
