sbc head gasket help
OK i need a little help here i was getting ready to mount my heads and the new felpro permatoque head gasket and i notice that the holes in the head gasket for the coolant port closest to the intake is not as large as the hole in the block .is this normal. i believe the block is was made between 1970 and 1980 the seriel number is 3970010 . i just do not want to have an overheating problem when i put this motor in my 69 c-10. take a look at the pictures and tell me what you think.
The oddest Todd around
Re: sbc head gasket help
I do believe that that is normal.
What I'm curious about is do you plan to install the gaskets dry, or are you going to use something on them like copper coat?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
i checked the instuctions and it mentions if it is a fiber faced gasket it is to be installed dry and if it is a metal faced gasket requires a thin even coat of sealer to be applied to the metal sides of the gasket.
~Rest In Peace~
yes dont put any rtv ,just install them dry as is ,
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#5 | |
I'm pretty sure that the bigger holes are there for the casting cores. The holes in the gaskets don't need to be any bigger than the holes in the heads.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Mine are the same like that and I compared my old gaskets to the new ones an there the exact same and the motor ran just fine. The only reason I took it out was to replace the clutch and decided to reseal the motor an put a one piece oil pan gasket in.
1969 Chevy c20(Miss Hackjob) |
#7 | |
Yes, that's normal, and yes put them on dry.
thanks everyone for the help. i did get the heads mounted. and now i have some questions on valve adjustments but that it in another thread labled sbc build (350)
