Old 11-13-2011, 07:44 PM   #1
kcfirstbuild
factory option numbers
does anyone know what the factory option numbers for a 307 and a sag 3 speed in 68 are ?
I know a 350 was some thing like LS9 and the Trans was M49
kcfirstbuild is offline   Reply With Quote
Old 11-13-2011, 08:16 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: factory option numbers
They weren't optional. I'm sure they had rpo codes... But they were base equipment so the codes will be a little hard to find
Old 11-13-2011, 08:56 PM   #3
kcfirstbuild
ok thanks - I'm trying to replace my factory firewall markings I have some numbers.
Old 11-13-2011, 10:11 PM   #4
bruceman1968
bruceman1968's Avatar
KC, The 307 code is L14. I'm not sure about your 3 spd. You can try here http://www.rpocodes.com/ or here http://outintheshop.com/options.html look in the m's like m15 through m19.
Sense your engine and tranny were standard they won't be on the SPID, I don't know about the firewall.
On the upper pass. side of the firewall was usually the model number, if that helps.
You did a great job on your 307 man, can't wait till you fire it up.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 11-13-2011, 11:16 PM   #5
bruceman1968
KC, Here's a good thread on firewall markings http://67-72chevytrucks.com/vboard/s...d.php?t=312454
Old 11-14-2011, 12:37 AM   #6
SS Tim
SS Tim's Avatar
Don't know where you would find that except in a GM parts catalog or possibly a protecto plate. Post exactly what you do have (SPID) and hopefully someone has the same truck with documentation. Even the dealer invoice won't show RPO codes for standard equipment.
SS Tim is offline   Reply With Quote
Old 11-14-2011, 09:48 AM   #7
kcfirstbuild
I scrubbed my factory markings off before I even knew what they were about. I can read some numbers. I had a post earlier but wanted to know if Some one could help me out again. All I have so far is the 541 AD CE10934 B In that order starting in the middle. I just have manual brakes so maybe be is all there was. I might but the motor number on just for fun
