Old 10-17-2011, 04:36 PM   #1
HTX86chevy
HTX86chevy's Avatar
wheel bearing trouble!
i have owned this truck for a little over 2 years now. Approx. Every 6 months the driver side wheel bearing dries up and falls apart on me. I replace the passanger side every time just to be on the safe side but its always in good condition. This is the 4th time that the driver side wheel bearing has worn out on me. I have replaced the rotor twice, also replaced the spindle once. I make sure that they are packed nicely with high heat disk bearing grease. Im sure i haven't over tightened the axle nut. Any suggestions. What could be causing only one side to wear out???
HTX86chevy is offline   Reply With Quote
Old 10-17-2011, 09:57 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: wheel bearing trouble!
are you stuck taking right turns haha jk. is your grease leaking out or just drying up?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-17-2011, 10:22 PM   #3
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
sounds like u need to start applying to jobs that perform lots of wheel bearing replacement/repacking, your gonna be a pro at it fast.
my suggestion is to make SURE your tightening axle nut correctly, it says to only tighten to like 15ish ft lbs then loosen and re tighten HAND tight so you MIGHT be over tightening the axle nut and not even knowing it.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 10-18-2011, 08:57 AM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
are you installing the grease seal ? when i do wheel bearings i grease up or pack my bearings i throw some grease on the race before throwing in the bearings and i grease up the axel shaft then i tighten up the spindle nut as per specs and put the wheel on..
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-18-2011, 10:56 AM   #5
SCOTI
SCOTI's Avatar
Is the grease seal still good between the backing plate & the spindle?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-18-2011, 05:38 PM   #6
HTX86chevy
HTX86chevy's Avatar
i'll have to check the seal when I remove the bearings later this week. But I replaced the seal also the last time. And the Grease is not just drying up. (well this time any way) It kind of just oozed out , so much that it pushed the CUP thingy that goes over the axle nut.
Old 10-18-2011, 06:20 PM   #7
Eyegore
What Hump?
Eyegore's Avatar
Few Questions
Are you replacing the rases with the bearing? Some skip this believing the old is still good and not pressing it out.
Are you using high tempature grease?
And could you possibly over greasing?
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 10-19-2011, 09:31 PM   #8
HTX86chevy
HTX86chevy's Avatar
I didnt know it was possible to over grease so this could be possible.
what is the race? Got a pic??? I just replaced the rotor today because the lip on the inside was broken..... this is the 2nd time. I have eveything needed to put back together so i'll try and get this done tomorrow..
Old 10-19-2011, 09:36 PM   #9
INSIDIOUS '86
try making your grease cap fit a little tighter i put a dent on the lip of my cap cause it leaked and would sometimes fall off, this should prevent your grease from disapearing
Old 10-19-2011, 11:40 PM   #10
willett
Another Day, Another Dollar
willett's Avatar
Bingo!
the race is that shiny metal sleeve that comes on the outside of the bearing when its in the box.
you need to knock the old one out and press the new one in everytime you do a wheel bearing.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-07-2014, 09:05 PM   #11
swissarmychainsaw
Even though this post is old, I was surprised that anyone would not replace both, so for instructional purposes here is a Race (left) and a Bearing (right).
They are two halves of rotational bliss, replace them as a pair.
swissarmychainsaw is offline   Reply With Quote
Old 01-07-2014, 09:41 PM   #12
mgchevyparts
mgchevyparts's Avatar
If using a new rotor no need to change the race as the one in the rotor is new.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 01-08-2014, 01:06 AM   #13
INSIDIOUS '86
Even with a new rotor that has new bearings races inside I still pull those out and run a matched set just to be sure. I'm sure nobody else has had a problem but I like to be sure.
Old 01-08-2014, 01:21 AM   #14
kelsfine69
18 Till I Die
kelsfine69's Avatar
I just did mine. New rotors, New bearings. Banged out the races and installed the new races that came with the new bearings. Toss the new races that came with the rotors. Repack the bearings with good bearing grease and coat the inside of the rotor with a bit of grease. Apply a thin layer to the spindle as well. New seals and install. Tighten the nut while spinning the rotor in the direction of nut tightening till the bearing seats. Back the nut off to the nearest hole for the cotter pin lineup. The rotor always has a bit of looseness to knock the pads back so they don't drag on the rotor. You wont feel this play but it is there. Always back off the nut to the nearest cotter pin hole, never tighten to the nearest hole.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-08-2014, 05:30 AM   #15
TwinTurbo
TwinTurbo's Avatar
I do the same, always install matched set
TwinTurbo is offline   Reply With Quote
Old 01-08-2014, 06:10 AM   #16
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The whole matched set deal is over blown. When you get into bigger bearings, they don't even come with races. You have to buy the bearing and the race separate from each other. That's not a matched set. I figure if it was a valid concern, Timken would have them sold as a set rather than two separate part numbers and boxes.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-08-2014, 10:24 AM   #17
swb85
On a budget like Fred Sanford
swb85's Avatar
^^^This.
Long as the bearing & race are both new it doesn't matter what box they came in. You just want to avoid a new bearing riding in a used race that already has an established wear pattern.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-08-2014, 10:37 AM   #18
Corts60
Just here to tinker
Corts60's Avatar
I agree.
Old 01-08-2014, 11:49 AM   #19
tony58
They're all matched sets as long as the bearing number and race number is correct.
tony58 is offline   Reply With Quote
Old 01-08-2014, 11:50 AM   #20
tony58
Originally Posted by swb85 View Post
^^^this.
exactly
Old 01-08-2014, 12:43 PM   #21
TwinTurbo
TwinTurbo's Avatar
Yes, because they are the same manufacturer, a race with the correct hardness and surface finish. No guarantee with an already installed race, what manufacturer is it? I wouldn't take the change, especially with the cot of a race and bearing set and the amount of work it usually is
Old 01-08-2014, 05:07 PM   #22
tony58
If you're concerned about the quality of the race in a rotor then I would think you should also be worried about the quality of the rotor itself. Truth is, they are made to the same specifications
Old 01-08-2014, 06:44 PM   #23
TwinTurbo
TwinTurbo's Avatar
These days I'm concerned with the quality of most things. Being in Europe, if I order stuff from Summit or the likes I get a bunch of paperwork stating country of origin for the products (some kind of homeland security thing I was told) and it's all China and thereabouts.
