Old 12-25-2010, 07:11 PM   #1
Heater63
Heater63's Avatar
Anchor point for shoulder harness?
what has everyone done to create an anchor point when adding a shoulder harness seat belt? Reinforce it with a plate?? I was going to hammer small piece of plate to match the contour, slide it up behind the cab wall, weld it through spot weld holes.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 12-25-2010, 07:32 PM   #2
iiizman
iiizman's Avatar
Re: Anchor point for shoulder harness?
One of the guys did it when he made his a big window. I am going to make mine a big window and put it behind the panel when I take it off.
Bad Decisions usually make for Good Stories.
iiizman is offline   Reply With Quote
Old 12-26-2010, 01:02 AM   #3
Captainfab
60-66 Nut
Yep, That's what I would do. You should be able to reach up there from the opening below with maybe a piece of steel temporarily tacked to the plate. Then break it off after it is welded to the sheetmetal.
Old 12-26-2010, 01:16 AM   #4
hardwaa
hardwaa's Avatar
SO-CAL sells plates with nuts welded, They are cheap and worked perfect I used them on my 66. Drill hole from inside cab through superficial panel and slide plate up behind panel just drilled with hand and thread bolt. Driverside had to remove fillerneck so my arm would fit.
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 12-26-2010, 01:51 AM   #5
Heater63
Heater63's Avatar
Thanks guys!
292 + TKO500
Old 12-26-2010, 12:14 PM   #6
taclem
taclem's Avatar
Hardwaa, Do you have any part number for the So-Cal anchor plates, I looked on a couple of So-Cal site and have not found them. They look like something I would like to buy.
Taclem
taclem is offline   Reply With Quote
Old 12-26-2010, 01:10 PM   #7
duallyjams
duallyjams's Avatar
wana see myself
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-26-2010, 01:29 PM   #8
TopFuel1966
TopFuel1966's Avatar
I bought my seat belts from Juliano's and the anchor plates for the shoulder belts came as part of the mounting package. I'm sure you could get them there also.
TopFuel1966 is offline   Reply With Quote
Old 12-26-2010, 01:40 PM   #9
777ralph
I did mine exactly the same way as Hardwaa did. There's no need to weld the plate in place. Just slide it up behind the hole you drilled, and thread the bolt on. Skinny arms help, or a tacked on "reach extender". The inner sheetmetal panelis pretty strong. It might deform a bit in a serious crash, but by that point you'd have bigger problems anyway.............
Ralph
777ralph is offline   Reply With Quote
Old 12-26-2010, 03:30 PM   #10
AZ66GMC
Desert Dweller
AZ66GMC's Avatar
Great info guys. I'm planning to install new seat belts in my 66 and this is how I will do mine as hardwaa suggested.
The So-Cal info is on the last page of this link http://www.so-cal-az.com/uploads/Int...pg_114-117.pdf
I'm gonna pick up a set tomorrow
Tony
Tony
66 GMC LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=399283
AZ66GMC is offline   Reply With Quote
Old 12-26-2010, 11:37 PM   #11
hardwaa
hardwaa's Avatar
AZ66GMC Thanks for posting a link. I am sure other venders have the same part.
NO BOZO's
Old 12-28-2010, 12:50 AM   #12
Chevy Fleetside
Chevy Fleetside's Avatar
I had to use a stick with the piece taped on because my hand/arm would not fit.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-29-2012, 08:14 PM   #13
Breadstick
Does anyone know if this would work with a 64? I don't think it would be any different but I'd like to be sure before I start drilling holes in my cab.
Breadstick is offline   Reply With Quote
Old 03-30-2012, 12:13 AM   #14
Heater63
Heater63's Avatar
Sure, should be the same. As 777ralph pointed out, there is no need to weld anything, just hold the backing plate in place at the time of install and your done.
Look at the pictures in the thread for placement, about 1/2 way up on the small rear window. Drill 7/16" hole, that is the size of the anchor bolts commonly used.
292 + TKO500
Old 03-30-2012, 07:02 AM   #15
Breadstick
Thanks for the reply. This will be my next project for the truck.
Old 03-30-2012, 10:23 PM   #16
777ralph
Mine is a 64. Worked great. I mounted mine back a little further toward the corner, but that's just where my arm fit. Put it high enough so it's above your shoulder, though. Check a new car for placement. Taking the tank out is the hardest part. With a bit of rod tacked on to the plate you might not have to do that.
Ralph
Old 03-30-2012, 11:20 PM   #17
Caudillo64
Caudillo64's Avatar
Ebay has them. I'm putting bucket seat in my 65 and I bought a set of 3 point seat belts with all three mounting anchors reinforcements in a package deal $119 shipped.
Caudillo64 is offline   Reply With Quote
