Old 07-07-2012, 09:39 AM   #1
fleetman
tracking arm stud removal ?
going with longer unit not mounted in stock location.
i have taken the stock tracking arm out and would like to remove the stud from the differential carrier. can this just be tapped out ? (like with a 5 lb. sledge hammer).... if so which way should i hammer... out towards the frontend ?
thanks
paul
66 long fleetside
fleetman is offline   Reply With Quote
Old 07-07-2012, 08:12 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: tracking arm stud removal ?
It "drives out",... toward the rear of the truck.
Keith
Convert to disc brakes.
Old 07-08-2012, 07:53 AM   #3
fleetman
thanks kieth. wanted to be sure-didnt want to bugger it up.
Old 07-11-2012, 10:16 AM   #4
RexDodge
Be sure to leave the nut threaded on but loose. That sucker will shoot out like a rocket!
RexDodge is offline   Reply With Quote
Old 07-11-2012, 11:37 AM   #5
fleetman
say thanks for the additional info rex. i have tryed to hammer this out ( with nut on - just so i dont marr the bolt threads) but it is in there good.
do you think i am just not hitting it with a big enough hammer and with enough force ?
think i will soak it with a little liquid wrench... might help.
Old 07-11-2012, 11:39 AM   #6
lolife99
lolife99's Avatar
Use a small sledge hammer.
It's tapered,... so you are just trying to break it off the taper.
Keith
Old 07-11-2012, 12:54 PM   #7
jimmydean
jimmydean's Avatar
BFH.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-13-2012, 02:33 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Yeah I remember something about it being funny lol soak it put a nut on it and bang on it with a brass hammer...
Listen to lolife99
John
1999 Toyota Tacoma 4x4
Old 07-13-2012, 03:15 PM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I used a air hammer with a point bit and it just popped out with no problems. Should have left the nut on as it kind of flew out... LOL
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-13-2012, 04:13 PM   #10
six-T-seven
Application of a little heat goes a long way to help loosen it up too.
six-T-seven is offline   Reply With Quote
