Old 07-25-2012, 04:13 AM   #1
AOH200
Need part number (steering)
Hello truck lovers
Can any one tell me the steering part number in the picture below:
My truck is a 69 C-30 2WD.
Thank You..
AOH200 is offline   Reply With Quote
Old 07-25-2012, 07:35 AM   #2
redsled87
redsled87's Avatar
Re: Need part number (steering)
Check with The Truck Shop in Orange CA. http://www.truckandcarshop.com They have those. I just bought one in April for my manual gear. That is called the rag joint or steering coupler.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 07-25-2012, 10:50 AM   #3
AOH200
redsled87
Thank you for the quick replay
Further, is this the part that you are referring to:
http://www.summitracing.com/parts/OER-C2553/
Old 07-25-2012, 11:05 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Originally Posted by AOH200 View Post
redsled87
That is the rebuild kit for the coupler/joint housing you already have. Sometimes when the rag joint goes bad, it is often not noticed until damage is to the point that the entire unit needs to be replaced...here is another source for a complete replacement:
http://www.classicperform.com/6092chevtrk.htm#44
...but most of the other vendors, Early Classics, Brothers, etc. carry steering rag joints...enter "rag joint" as your parts search.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-27-2012, 09:36 AM   #5
AOH200
vin63
Thank you for your suggestion,
Also, can you help me figuring the best size for a 69 Chevy truck?
Old 07-27-2012, 11:32 AM   #6
vin63
vin63's Avatar
vin63
You'll need to confirm the spline count on the steering box input shaft and the corresponding size of the steering shaft. If this post was a few weeks earlier, I could've checked for you in person since I was in Chester, Il to visit in-laws.
