Old 10-01-2012, 01:50 PM   #1
dagall
Underbed Tank Fuel Lines
I have a "92 stepside bed on my "72 and am getting ready to install a under bed tank. There is a filler door in front of the left rear wheel in the fender. Is that to long to run filler hose to? If not, that would make things pretty simple instead of cutting holes in the bed or somewhere else.
1972 Chevy C10
Shortbed/Wood
Starting LS1 GTO Swap
dagall is offline   Reply With Quote
Old 10-01-2012, 04:35 PM   #2
cdowns
cdowns's Avatar
Re: Underbed Tank Fuel Lines
i'd think that is too far to run t and would b nothing but a problem and if you got it run i'd think to fill it at the pump wood take u hours
Old 10-01-2012, 06:59 PM   #3
gotchamel
Shorter the run the better but why not try it before you go cutting holes.Your only real expense would be the length of fill hose,you could even use clear vinyl cause its cheap to see how it works.Obviously the clear is not fuel hose and would only be a test.
gotchamel is offline   Reply With Quote
Old 10-01-2012, 07:31 PM   #4
longorange68
Fill hose is cheap, go that route. Go talk to a diesel repair shop, I got a long section for my truck from one of these outfits. Apparently garbage trucks they worked on needed it..
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, 700R4, 3.73 gears
Good judgment comes from experience, and experience, well......that comes from bad judgment.
1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then.
longorange68 is offline   Reply With Quote
