Old 12-09-2012, 12:57 AM   #1
cmyc5575
turn signal question?
Hello all, I have been having issues with the driver side front turn signal not wanting to flash at all. I noticed that the side marker light wires were cut rite behind the socket so I bought a new socket and also the turn signal socket that is in the bumper. I havent gotten a chance to put the bumper socket in yet but did put the side marker socket on and when i turn the lights on the side marker lights up like it suppose to, but the turn singal inside the cab stays dimly lit. Is this normal until i replace the turn singal socket to or could i have a crossed wire some where? Also not sure if Im wiring the colors up correctly the replacment that i bought has one brown and black wire and the stock was blue and brown.
cmyc5575 is offline   Reply With Quote
Old 12-09-2012, 01:21 AM   #2
J Knight
J Knight's Avatar
Re: turn signal question?
You basicly have 3 wires to each turn signal socket and 2 wires to each marker light.
Turn signal socket
1. power for park/run lights
2. flashed power for blinker
3. ground
Marker light
2. ground
It seems that you used power #1 and flashed power #2 for a ground wich is feeding back to your cluster/blinker indicator.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-09-2012, 01:26 AM   #3
cmyc5575
Turn signal socket
3. ground
Marker light
2. ground
Ok what about the colors the replacment that i bought for the marker lights is brown and black where the stock is blue and brown. How should i hook them up? I thought that brown was ground on the stock so i hooked the black up to the brown. Funny thing is even when you wire it both ways the marker is coming on and still feeding back to the cluster, take in mind i still havent hooked up the turn signal socket.?
Old 12-09-2012, 01:30 AM   #4
J Knight
J Knight's Avatar
The wires you have crossed are from your truck, not the light.
John
Old 12-09-2012, 01:34 AM   #5
cmyc5575
So, its not neccessarily that I havent put the turn singal on or that i have the wrong color hooked up to the incorrect wire color, but a crossed wire somewhere else in the truck?
Old 12-09-2012, 01:40 AM   #6
J Knight
J Knight's Avatar
Turn signal socket
3. ground
Marker light
2. ground
You have connected either the marker light or the turn signal socket ground wire to the wrong wire "from your truck harness". Im not sure about the colors of the wires from your harness or your replacement sockets but a test light will easily tell you wich wire is wich from your truck harness.
John
Old 12-09-2012, 01:44 AM   #7
cmyc5575
My Harness= One blue and one Brown
Replacement marker socket= One brown and one black
I havent wired the turn signal socket yet. How does the test light work? Sorry real new to all this.
Old 12-09-2012, 01:51 AM   #8
J Knight
J Knight's Avatar
You can connect the marker socket either way as long as its the original 2 wires. Cut the original turn socket off and see if it is what is feeding back to your cluster.
John
Old 12-09-2012, 01:55 AM   #9
cmyc5575
I cut the turn signal socket and the marker light both off. Thats what im saying that is that after i cut them both off all i have put on was the marker socket and the three wires that i have for the turn socket are just dangling near the bumper.
Old 12-09-2012, 02:01 AM   #10
J Knight
J Knight's Avatar
I honestly dont know how to explain this anymore without being there and seeing what you are working with.
John
Old 12-09-2012, 02:03 AM   #11
cmyc5575
I honestly dont know how to explain this anymore without being there.
Lol sorry man, My friends always give me a hard time about being hard headed. Ok let me ask this, Just having the marker socket hooked up and leaving the three turn signal wires not connected cause this issue?
Old 12-09-2012, 02:06 AM   #12
J Knight
J Knight's Avatar
EDIT: Actually I think it would.
John
Old 12-09-2012, 03:45 AM   #13
cmyc5575
Lol we'll I got it home and hooked up the turn signal light and now it's working with only one issue now. The driver side wants to stay solid when I turn the lights on. But the signals work correctly. What is causing that?
Old 12-09-2012, 11:23 AM   #14
J Knight
J Knight's Avatar
If I understand you correctly, you connected the park light power and the blinker power backwards. I think you need to switch them.
John
Old 12-09-2012, 03:50 PM   #15
cmyc5575
On the turn socket or the marker socket?
Old 12-09-2012, 08:32 PM   #16
J Knight
J Knight's Avatar
The turn socket.
John
Old 12-09-2012, 11:37 PM   #17
cmyc5575
The turn socket.
I ended up switch them and would still light up but then wouldn't signal
Old 12-10-2012, 02:13 AM   #18
zaccaglin
zaccaglin's Avatar
Sounds like you have a ground and hot reversed for the marker. Basically when you hit the blinker it's hot is hitting the hot from the marker light instead of ground. Have you blown any fuses?
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 12-10-2012, 04:28 AM   #19
cmyc5575
I honestly haven't checked that yet. I will tomorrow and see what it is.
Old 12-10-2012, 05:38 AM   #20
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Your side marker light isn't grounded in the traditional sence. True, you do have 2 leads going to it and they are BROWN = PARKING LIGHT CIRCUIT & BLUE = TURN SIGNAL CIRCUIT.
If you look at your marker light on the right side with the lights on and the right turn signal activated, you will see that the side marker flashes alternatingly with the front facing turn signal.
You can test your new socket with a bulb in it to find which lead is the park lead and which is the turn lead.
Touch the ground lead to the negative side of the battery then touch one of the other leads to the positive terminal and note how bright the bulb is.
Now release the lead on the positive and touch the other wire to it, again noting the brightness of the bulb.
The brighter lead is the turn and should be connected to the blue wire from the truck and the other(dimmer lead) to the brown wire on the truck and of course ground to the black wire on the truck.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-10-2012, 09:12 PM   #21
cmyc5575
Ok I managed to get it working but still can't figure out why when my lights are on the turn signal is staying solid. The turn signal works tho.
Old 12-11-2012, 12:30 AM   #22
BLE 'BURBAN
Check your bulbs Front and rear. MAke sure they are both the same part #.
I once upgraded the tail light bulbs in my old 74 cutlass from 1n 1157 to an 2057 and they wouldn't flash. I changed out the front 1157NA (NA = Natural Amber) to a 2057NA and WALLA they worked great!!!!!
Also double check all grounds front AND rear.
Also have you checked it out with your hazards? Maybe try swapping the flashers around between your turn and hazzards. Worth a try....
Old 12-11-2012, 06:14 PM   #23
cmyc5575
Ok, I asked my dad for some assistance with the lights. He told me that the reason why the turn singal stays solid when I turn on the head lights is it made to do that for this year and then he told me that it may be my passenger side turn singal socket and may want to check it out. So guess what, he was right one of the bulb contacts had corroded on the passenger side and was perventing it from not lighting it up when the head lights are turned on so I went to orileys and got it replaced and now they are working correctly. I DIDNT THINK THAT MY YEAR TURN SINGALS WERE SUPPOSE TO STAY SOLID WHEN THE HEAD LIGHTS CAME ON IF THIS WAS THE CASE I WOULD HAD TO HAVE WORRIED ABOUT THE STRESS LOL.
Old 12-12-2012, 11:34 PM   #24
BLE 'BURBAN
WHO-DA-THUNK-IT!?
Old 12-12-2012, 11:58 PM   #25
cmyc5575
WHO-DA-THUNK-IT!?
Lol even tho I was feeling accomplished for doing my first somewhat wire job I was alil pissed about it bc it was sooooo simple.
