Replacement Radiator
I have a 67 GMC 3/4 ton 250 I6. The radiator leaks and if it cant be repaired I will have to replace it.
I have seen on some websites a heavy duty radiator for my truck but NAPA only has one radiator listed for my application. I could put in a 3 or 4 core design for automatics. I plan on towing with it so if a heavier radiator will fit then..... 1. will it hurt to run a heavier radiator or will it overcool the 250I6? 2. will it fit in the current location the stock radiator is in? Thanks |
Re: Replacement Radiator
If you have a o'reilly's in your area go see them, thats where i got mine and it fits good and they are cheaper.
having said that a larger one 3or 4 row will fit but you will have to have hold down clamps for that size "they are thicker". as far as running cooler the thermostat will take care of that. hope this helps.
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
No such thing as overcooling. That's why engines have a thermostat.
I just bought a 4-core from Autozone online. Installed it on Sunday. They had 2 different online coupons, so I got it pretty cheap with free shipping. It has connections for automatics, but is considered universal. You don't even need to plug the trans line ports. Fit perfect and no issues at all. http://www.autozone.com/autozone/par.../N-iqh3mZ9pdak I think with the coupons I got it for $130 shipped.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Autozone 4 core is what I put in mine in Arizona. Price same as above. Good quality, believe made in Canada by Superior.
Mine has a made in Canada sticker on it.
![]() Join Date: Feb 2011
I got mine from O'Reilly's a little over a year ago for $ 194.34 . It is a 4 core, with a life time warranty. And you can not have to much radiator if you have a working thermostat.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
I am a Referee of life.
O'Rielly's.I put a 4 row in m 68 with the 250,Heats up about as quick as the 2 row,runs cool all the time but heats well for the heater.I was in it for less tha $250 with new mounts,rubbers and top hose.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
