proper backspacing for 20" Coys
i'm def leaning towards getting some 20" coys wheels,...looking at 20X8.5 in the front and 20x10 in the rear.
for tires, i'm thinking 255-40-20 in the front and 295-40-20 in the rear. they offer two different options for backspacing in those two size wheels, for the 20x8.5, they offer 4 3/4 ", 5 1/4" inch for the 20x10", they offer 5", 5 1/2" inch i'm going 5/7 drop with shackles/flip kit rear, springs/spindles up front what do you all recommend? stance is everything, and i dont want to mess it up by getting the wrong stuff thanks
1987 350 TBI lowered 5/7 |
![]() Join Date: Aug 2008
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: proper backspacing for 20" Coys
I would go max backspacing front and back since you are going that low.
Down......with the sickness!! |
Not sure about the fronts but I think even with a 5" BS for the rear the wheels will sit in too far and you will need a spacer.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
Here are my Coys. 20x8.5 with 5.25 and 20x10 with 5.00
2010 Tahoe 1984 C10 2005 Harley FLH 1941 Willys Pickup (will never get it done) not for sale Last edited by 1984 swb chevy; 03-16-2009 at 09:26 PM. |
Bigarmzz, I think crawdadfox has the answer . I am having my 20x10's built with 5.25 inches of backspace and will be running the same tire size you mentioned . I measured the wheeltub and there is about 14 inches of clearance under there . 5.25 sitts it a little closer to the outside than the inside but it will give a nice amount of clearance on both . I know 4.5 inches of backspace will rub the outside . That being said , I would order the 5.5bs so you will have clearance . If you could get a 5.25 I would say go with that but since you only have two choices ,5.5. If I ever order Coys , they will be the max backspacing .
Frank
Born and proudly residing in a Red State ! |
Slugish
![]() Join Date: Jan 2005
X 2 ON FRANKS & OTHERS COMMENTS > MAX BACKSPACING ON THE SIZES YOU WANT. lOT OF MONEY TO SPEND ON SOMETHING THATS GONNA RUB.
*NO REGRETS*
So, if I've calculated right 22x9's with a 5.5 bs in front and 5 in the rear should be perfect on a square body? Laid out of course!
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Yes buddy, max backspace front and rear.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
*NO REGRETS*
Max in the rear would be 5.5? I was thinking I could get away with 5?
with 5.5 on the rear how much tire to fender room is there i know it depends on tire width but just a appox. would be ok !
1 what is the narrowest tire i can put on a 8.5 inch rim i dont care for that wide front tire look !!!!
78 C-10 5.3 LSX -4L60E |
I would do 20x8.5's w/5.25" on front & 20x10's w/5.50" in the rear. The rears fit well w/the described drop. Depending on amounts of spindle + springs, the front tire choice might be a bit tall for that drop though....
Nice truck Scoti. I love ur stance with the rims. Anything diffrent for the stepside or its all the same.
hey Scoti truck looks great! What size tire are you running in the rear? Thanks
295-40's.
#15 |
Scoti nice truck what size you running up front and how much drop..thanks
#16 | |
I didn't run the Coy's on there for more than a few hours because the front tires constantly buzzed the top of the inner wheel wells (they were purchased for my 68 but I put them on the 74 to see if I liked the grey wheels w/that paint scheme). I definitely needed some modified wheel wells for that combo.
#17 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Good BACKSPACE thread to bring to the top!
