Old 10-07-2013, 08:40 PM   #1
Pano
new leafs installed w/ pics
Truck is an 87 GMC V2500. Tires are 235/85/16's in both pics.
The front had 2 leaf and the rear had 8 leaf rated at 2450 lbs. I replaced the front with 3 leafs rated for 1400 lbs and rears with HD 8 leafs rated at 2600 lbs from General Spring.
I have never driven in an old truck with soft springs so I cannot compare the ride but I use it to tow and haul and don't care so much about the ride.
I don't know if it sits higher than stock since my stock springs were worn but I like how it sits now.
Stand by for pics.
Pano is offline   Reply With Quote
Old 10-07-2013, 08:48 PM   #2
Pano
Re: new leafs installed w/ pics
Having issues uploading pics
Old 10-07-2013, 08:53 PM   #3
Pano
I have uploaded from my pc before but it won't seem to work now. (shrug)
Old 10-07-2013, 08:55 PM   #4
Pano
This is from around 2002 after paint.
Old 10-07-2013, 08:57 PM   #5
Pano
This is from today with the new springs (same tires)
Old 10-07-2013, 11:51 PM   #6
Chevy3+3
Slick truck you have there. Very clean looking. Looks like you may have gained an inch in height. I wish General Spring made some lift spring packs because they have a nice HD 4 leaf thick front spring for my 1 ton. That should hold up to the 454. I just want a set of springs to bump me up about 2 1/2" and wont break down from the weight of the big block
Chevy3+3 is offline   Reply With Quote
Old 10-08-2013, 05:56 AM   #7
Pano
Thanks...I bought the truck in 97 and had it painted around 2001/2. At the time a buddy of mine worked at one of the GM factories and I scored a bunch of O&M parts. ( doors, front bumper, tailgate, grill, fender wells, trim, etc.) If I had known which parts would become scarce I would have picked up some other stuff.
Anyway my truck has the 350. Maybe you can go with the 4 leaf and a zero rate 1 inch block to hopefully Get 2-2.5 inches.
Old 10-08-2013, 01:04 PM   #8
Ski-me
Ski-me's Avatar
Looks nice. I like the new wheels better too!
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 10-08-2013, 04:36 PM   #9
crashz
crashz's Avatar
Sweet truck Pano! Hope to see you cruising around MA someday!
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
