Old 02-22-2014, 11:14 PM   #1
lenguini
lenguini's Avatar
Hide the wires to the hood,need help !
Just looking for some ideas on how to hide the signal wires running up to the hood...any ideas ? So far thinking about the stainless sliding door loom but its a little bulky.
The new wires are running from the existing hole in the cowl at the passenger side.I have maked it with a red circle- into the hood and then hidden under the brace's.I'm just not sure what to use to hide them from the cowl to the hood itself.
At one time I thought about installing a contact that completed the circuit when the hood closed but I dont know this would work.
Appreciate all input here.
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 02-22-2014, 11:28 PM   #2
65Gregg
65Gregg's Avatar
Re: Hide the wires to the hood,need help !
I think Watsons Wire works has a good selection of contacts that will do the job.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 02-22-2014, 11:40 PM   #3
lenguini
lenguini's Avatar
Thanks,I'll have a look on their site, rather go this way than the loom.
Old 02-22-2014, 11:51 PM   #4
lenguini
lenguini's Avatar
Nope,just checked.Nothing at Watsons.
Old 02-23-2014, 01:52 AM   #5
LVPhotos
LVPhotos's Avatar
Painless web style? The factory one not working? It does go under the brace. Or how about door plunger with brass connection where they touch when closed but not when open?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-23-2014, 01:56 AM   #6
LVPhotos
LVPhotos's Avatar
http://www.speedwaymotors.com/Painle...ire,34103.html
Old 02-23-2014, 02:26 AM   #7
lenguini
lenguini's Avatar
What do you mean by the factory one ?
Old 02-23-2014, 04:48 AM   #8
BigDan3131
BigDan3131's Avatar
I'm going to use the Jamb Tacs.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 02-23-2014, 11:01 AM   #9
LVPhotos
LVPhotos's Avatar
The factory wire loom plugs into the firewall on driver side and runs under factory hood brace to driver light then accross nose to passenger side.
Old 02-23-2014, 12:50 PM   #10
lenguini
lenguini's Avatar
I may have took for granted you were following my build thread when I asked you the question.There is very little left on this truck that has factory anything,or atleast period correct.The new harness will not route anywhere near where the old one did,for the specific reason I'm attepmting to hide all wire completely.
I have looked at the Painless contact option however with the amount of vibration in these hood's,I doubt the contact points would meet properly for long and more than likely wear out quickly and create a weak point in the circuit.
Its unfortunate that available contact options are really designed just for doors,which do not have the movement you would experience in a hood.
After many hours searching I may have found a solution.This contact product has a more forgiving surface area.
