Old 11-23-2013, 06:04 PM   #1
mikeandson
63 horn cup help
Trying to pull my steering wheel and I pulled the horn button and encounters those nasty little wierd screws. See pic. Can anyone tell me what bit will get these out? My local Autozone "pro" had no idea.
mikeandson is offline   Reply With Quote
Old 11-23-2013, 06:12 PM   #2
davbowen
davbowen's Avatar
Re: 63 horn cup help
called a clutch head screw. should be to turn them with a flat tip screwdriver, at least I did.
davbowen is offline   Reply With Quote
Old 11-23-2013, 06:21 PM   #3
mikeandson
Thanks a bunch!
Old 11-23-2013, 06:37 PM   #4
Daze57
Daze57's Avatar
spray them real good with pb blaster - should turn using a flat blade
Daze57 is offline   Reply With Quote
Old 11-23-2013, 07:41 PM   #5
mikeandson
Thanks. Anybody know the proper bolt diameter and thread pattern to use with the puller? The bolts in the kit don't work.
Old 11-23-2013, 08:23 PM   #6
VonDog
VonDog's Avatar
I heard that they're called Double D. Had them on my door handle on the inside and also on my accelerator pedal. Just used a large flathead screwdriver. And PB blaster!!!
VonDog is offline   Reply With Quote
Old 11-23-2013, 08:39 PM   #7
bj383ss
bj383ss's Avatar
I just pulled mine. I used 5/16" coarse thread bolts. Not sure if it was right as mine had pretty bad threads, but I tried some fine thread and they definately didn't work. The steering wheel on mine came off while I was tightening the bolts on the puller down! Real easy. Mine didn't have the D Bolts.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 11-23-2013, 08:54 PM   #8
mikeandson
Bret
Thanks Bret. I tried 5/16 fine. It wouldn't go in, but I felt like the bolt was too big. Just wanted to check before I went and purchased a bunch of different bolts.
Old 11-23-2013, 09:29 PM   #9
Grandpa54
Grandpa54's Avatar
They are clutch heads i have had a set for years you could probably google it and find a set. The 30s avd 40s chevy used a lot of them.
Grandpa54 is offline   Reply With Quote
