Old 06-23-2007, 08:04 PM   #1
RustMaster87
RustMaster87's Avatar
Gas tank year Differences, 73-81,-82-86,87
I have been flipping through the catalogs and have noticed that they list different gas tanks from 73-81, 82-86, and also 87. What is the difference in dimensions, length width, overall shape? I know they make different versions for gallon capacity, but are these tanks interchangeable? I ask this because I have the gas tank out of an 87 fuel injected truck, and a 1980 frame. I hope there is not a difference as I scored this tank for free.
I also have the 3 outlet fuel sending unit from the same tank that is in good working order, could I make this work with a carb?
RustMaster87 is offline   Reply With Quote
Old 06-24-2007, 12:18 AM   #2
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Re: Gas tank year Differences, 73-81,-82-86,87
73-81 have smaller filler necks than 82-86. 87 has a sump pan (like a little cake pan) under the sending unit to keep the fuel from sloshing away from the in-tank electric pump they used that year. The pan interferes with the float on earlier fuel senders.
The other dimensions didn't change between styles (but are different between the two sizes).
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 06-24-2007, 09:57 AM   #3
scotty101
So can you use a tank out of a 82 and put it in a 87 with efi? or do you have to switch the pumps or will it not work?
scotty101 is offline   Reply With Quote
Old 06-24-2007, 11:44 AM   #4
RustMaster87
Well it looks like I am going to have to buy a different fuel tank and sending unit. Not what I wanted to hear but hopefully I will be able to sell what I have. I was thinking about putting a fuel cell in the bed, guess I have some thinking to do.
Old 06-25-2007, 05:37 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You can use the 87 EFI sender in the '82 tank, but not the 82 sender in the 87 EFI tank. If you use the '82 tank you won't have the baffeling that was mentioned previously, the biggest negative is if you run the tank low it could stall because of uncovering of the sump.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-17-2014, 12:10 PM   #6
BADAZ chevy guy
BADAZ chevy guy's Avatar
I've been talking here>>> http://67-72chevytrucks.com/vboard/s...d.php?t=625156 about tanks that I got when I bought a 1977 C10.
New question. Do the 16 gal and the 20 gal tanks mount with the same saddle mounts?
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
