Pinion angle
Hello all,
Just looking for some opinions on my pinion angle before I commit to a course of action. The truck is a 72 Jimmy with 4" tough country springs in the front, ORD shackle reversal and 2" tough country springs in the rear. The truck sits nice and level with the top on and no longer looks like a dog dragging his hind quarters on the carpet. The shackle flip and converting from an automatic transmission have left me with a 10 degree difference in drive line angle and pinion angle. I'm wondering with the six inch total lift in the back if the drive line angle is too steep for single u-joints? Option (1) a 10 degree shim from DIY4X4 for under $50 Option (2) cut off and weld on new spring perches for under $50 Option (3) go to a double cardan joint in the rear which will be expensive to have a drive shaft built. Thanks for your input Last edited by audaciousduo; 12-08-2014 at 11:28 AM. |
![]() Join Date: Aug 2008
Re: Pinion angle
Go with the double cardan joint driveshaft. With the short wheelbase and 4-6" of lift you will operating near the max working angles of the single joints.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
Re: Pinion angle
Thats what I was afraid of ....... spendy
Re: Pinion angle
Anyone ever deal with these guys or recommend a supplier?
http://www.dennysdriveshaft.com/c4_4x4_driveshafts.html |
#5 | |
Re: Pinion angle
they do awesome work, cant say anything but good about them, they built my cardon'ed fr shaft for my 8" lift crew, some of my buddy's are running their shafts as well with zero probs http://www.abbyspring.com/driveshafts.asp |
Re: Pinion angle
I used a flange on the output shaft and used a stock 1350 cv from a 99+ super duty truck. Strong and plentiful. You can retube it pretty reasonably. If you're staying 1310 jeep xjs have a good front cv shaft to use.
Re: Pinion angle
I'll look into Abby spring and check the not so local wreckers for the other bits.
Thanks |
