Old 01-25-2015, 11:09 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
clutch pedal/master cylinder ?s
I just put the clutch/brake pedal assembly into my k5 and put the steering column back in. When I was putting in the clutch master cylinder I noticed I might not have all the parts to attach the 2 together. Basically is there a spring and small bracket similar to the one on the brake pedal that keeps the rod from coming off? I see a hole where a small bracket could be bolted on the clutch pedal.
Also, the switch for the brake lights has 2 sets of connectors, I assume one for the lights and the other for cruise control? Cruise control was not on my K5 when I bought it and I was thinking of removing all the stuff as follows:
On the pedal assembly(pass side) close to the firewall is a bracket with a relay I assume mounted. And on the opposite of the pedal assembly is another bracket with something else mounted. I think these both go to the cruise control, am I correct? I can get pictures tomorrow if that will help.
Thanks,
Jim
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-28-2015, 09:15 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: clutch pedal/master cylinder ?s
How about a picture of the clutch rod/clutch pedal connection point? (85 and up)Thanks,
Jim
Old 01-31-2015, 09:03 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Anybody?
Old 01-31-2015, 09:46 PM   #4
nonstop
Was just in there today! The eye of the rod just slips over the lie stub on the clutch pedal and is held in place with washers and the clip (yes, like the brakes). The bracket you are talking about sounds like it might be a bracket for the neutral safety switch. I took mine off long ago, so I can't remember. I hope that is what you were asking about.
nonstop is offline   Reply With Quote
Old 02-01-2015, 09:11 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks nonstop, that helps. I have that hooked up now. Another member enlightened me on all the switches on the brake pedal- cruise and torque converter lock-up and of course the brake lights.
