Old 03-08-2015, 12:28 PM   #1
85/Silverado
85/Silverado's Avatar
Lowering Help
I want to drop my 1985 Silverado C10 so my 4'10" wife can get into the truck easier without doing any cutting to the frame. maybe just some spindles 2 1/2 front and whatever in the back.
85/Silverado is offline   Reply With Quote
Old 03-08-2015, 12:37 PM   #2
85/Silverado
Re: Lowering Help
I have a lot of clearance as you can see.
Old 03-09-2015, 10:18 PM   #3
85/Silverado
Re: Lowering Help
Can I run the Leaf springs under the axil and get shorter shocks? Or will that effect handling?
Old 03-10-2015, 01:30 AM   #4
tinydb84
tinydb84's Avatar
Re: Lowering Help
You should probably use the search button but shackles/hangers will give you 4 inches and level you out with the drop spindles in the front.
David
Instagram: myfabguy
Old 03-10-2015, 08:28 AM   #5
bluex
bluex's Avatar
Re: Lowering Help
You can flip the rear springs an get shock extenders so you can still run stock length shocks. You'll need to cut one coil off your stock springs up front or get 2" drop springs to go with the spindles or the back will be lower than the front.
Flipping the axle won't negatively affect the handling
bluex is offline   Reply With Quote
